Axle Popped half out, now wont come out of trans???? 6ft prybar..nothing help ASAP!!
Ok i just installed an obx lsd and put the axles in,.. but i took the clips off the axles because i was having a hard time getting them in. Well i drive about 3 miles takin it pretty easy cause i have to break the clutch in. Well the axle popped out and i got it towed home and now i used everything from a 2ft-6ft prybar, WONT BUDGE a bit, I even took the right axle out and for a punch and try banging it out through the hole in the diff?... bottom line it wont come the **** out!
can anyone please help me... hopefully the diff isnt messed up.
this a a 91 civic d series btw. Thanks!
i dont know man, seems like the pattern on the axle stripped and got caught up with the pattern on the LSD, if i were you id take it to a machine shop and have them help you since u already tried all that with sooo much force
take it to a machine shop have them pull it out for you, then take apart that tranny and see what u did wrong
racin_jayson
Feb 6, 2008 03:10 PM
shauniewalnuts
10
May 3, 2005 12:37 PM
shauniewalnuts
Mar 30, 2005 09:08 PM
