Axle Popped half out, now wont come out of trans???? 6ft prybar..nothing help ASAP!!
Ok i just installed an obx lsd and put the axles in,.. but i took the clips off the axles because i was having a hard time getting them in. Well i drive about 3 miles takin it pretty easy cause i have to break the clutch in. Well the axle popped out and i got it towed home and now i used everything from a 2ft-6ft prybar, WONT BUDGE a bit, I even took the right axle out and for a punch and try banging it out through the hole in the diff?... bottom line it wont come the **** out!
can anyone please help me... hopefully the diff isnt messed up.
this a a 91 civic d series btw. Thanks!
Re: Axle Popped half out, now wont come out of trans???? 6ft prybar..nothing help ASAP!! (suckawilli
do you think the diff is f'd?? the teeth? or just the end of the axle spline??
The clips you removed are what keeps the axles in the diff. Sounds to me like you really jambed that SOB in there while driving. You probably fucked the new diff. up by gouching the axle into it at a fucked up angle. Good luck with that
Re: Axle Popped half out, now wont come out of trans???? 6ft prybar..nothing help ASAP!! (shaun311)
bump, took out the trans and took it back apart still wont budge i am about to drop if off somewhere
shauniewalnuts
10
05-03-2005 12:37 PM
shauniewalnuts
03-30-2005 11:48 PM
