climate control?
Old Mar 30, 2005 | 07:27 AM
GreenTeaLS's Avatar
Default climate control?
Hey whats up guys, i have a 1997 Acura Integra LS and the area above my radio, where one of the vents are ( left side ) broke, ( basically i had a sparco seat ( cell phone holder) and took it off too roughly and accidentally broke a piece off the vent, and now i need to remove the console, or whatever thats called, how do i remove it?? please help honda-tech, thanks
Old Mar 30, 2005 | 07:31 AM
Beatkidd's Avatar
Default Re: climate control? (CypressGreenLS)
remove the hazard and defrost buttons there are 2 screw points behind them
Old Mar 30, 2005 | 08:15 AM
GreenTeaLS's Avatar
Default Re: climate control? (Beatkidd)
once i take out the hazzard/defroster buttons, and remove the 2 screws, do i just pull it out, or are there more screws to take out, thanks for the help
Old Mar 30, 2005 | 09:17 AM
iH8RICERZ's Avatar
once you remove those two screws behind the hazard and defrost button, the climate control is only holding in place by clips. Just pop it out, then undo the 2 or 3 plugs/harnesses (need small hands), then go look underneath the passenger's side of the dash, find the temp cable and undo it off of the hook that its on. From there, the whole unit should pull out
Old Mar 30, 2005 | 09:24 AM
yangrou8's Avatar
Default Re: climate control? (iH8RICERZ)
follow this: http://www.team-integra.net/se...D=586
when replacing the cable, i found it easiest to lay on my back and watch the cable thread through the channel. make sure u replace the cable through that channel or u may have trouble with ur climate control lever.
Old Mar 30, 2005 | 09:51 AM
GreenTeaLS's Avatar
Default Re: climate control? (yangrou8)
thanks to everyone for the help
Brake_Check
Dec 18, 2013 10:29 AM
AznBlueBoy
Jun 13, 2011 03:47 PM
Homotor
Jul 26, 2009 08:47 PM
ner0x
Jun 23, 2005 07:17 PM
deez nuts
Jan 20, 2005 03:30 PM
