Timing to ADV or Retarted for SMOG
Old Mar 30, 2005 | 02:55 AM
GsR-Freak's Avatar
Default Timing to ADV or Retarted for SMOG
hmm i forgot which is which now..
my car is running rich, i use the vafc2 to lower the richness, if the car is running a little rich....to help for smog, which timing should i adjust to? advance or Retart?
it's Advance i think..but to make sure...illl ask you guys agian thanx
Old Mar 31, 2005 | 12:56 AM
GsR-Freak's Avatar
Default Re: Timing to ADV or Retarted for SMOG (GsR-Freak)
ttt
Old Mar 31, 2005 | 02:48 AM
GsR-Freak's Avatar
tttttttttttttttttttttt
Old Mar 31, 2005 | 09:17 AM
psychotic_z's Avatar
You're looking for a more complete burn, so advance the crap out of it.
Old Mar 31, 2005 | 09:24 AM
gsrious's Avatar
why don't you just turn it back to stock timing...and lower fuel pressure
Old Mar 31, 2005 | 09:33 AM
MAV3RiCK478's Avatar
Default Re: (red dc2)
you know your timing has to be to spec or they fail you. i was off 3 degrees advanced and they failed me.
Old Mar 31, 2005 | 10:02 AM
Marauder's Avatar
Default Re: (MAV3RiCK478)
Yep...you have to run stock timing to pass smog.
Old Mar 31, 2005 | 11:23 AM
blacknbean's Avatar
Default Re: (Marauder)
for cali its stock +/- 2 degrees for you to pass the timing part..so you can retard or advance a litttle bit and still be ok
Old Mar 31, 2005 | 02:32 PM
Default Re: (blacknbean)
actually its +/-1 for hondas/acuras or maybe thats just at test only but thats what the tech told me. for all other makes its +/-3
Old Mar 31, 2005 | 03:23 PM
ingrate's Avatar
25 Year Member
to reduce HC output you must retard the timing. When i was failing 5x over, i retarded the timing from 18 to 14 and my HC's dropped by 20% to around 420 ppm. (half of my cat was blown out, long story)
Old Mar 31, 2005 | 03:58 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">actually its +/-1 for hondas/acuras or maybe thats just at test only but thats what the tech told me. for all other makes its +/-3</TD></TR></TABLE>
That tech is wrong. Factory specs is +/-2 degrees.
Old Mar 31, 2005 | 09:35 PM
Evo-man@20psi's Avatar
I dunno but good luck
Old Apr 1, 2005 | 07:38 AM
Default Re: (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">That tech is wrong. Factory specs is +/-2 degrees. </TD></TR></TABLE>
yes i know that factory spec allows +/-2 degrees but to pass smog they have stricter guidlines. maybe its just for my car because it so old but he told me honda and acuras had to be within 1 degree of the factory setting.
Old Apr 1, 2005 | 09:04 PM
yes i know that factory spec allows +/-2 degrees but to pass smog they have stricter guidlines. maybe its just for my car because it so old but he told me honda and acuras had to be within 1 degree of the factory setting.</TD></TR></TABLE>
I doubt that's true. When I had my 91 DA the same rules applied to my car: +/-2 degrees. Sounds like he's talking out of his ***.
Modified by sleeperciv at 12:53 AM 4/2/2005
Old Apr 1, 2005 | 11:37 PM
TeamInlineB18B's Avatar
i went to the smog ref and i passed as long as it was +/- 2 degrees from stock which is 16. and thats at the SMOG REF STATION so whoever told you that was bullshitting you
Dazer 1991
Aug 15, 2012 07:09 AM
methos713
Jul 28, 2008 08:51 AM
MIZIKETSK
Sep 16, 2003 08:13 AM
B2FiNiTY
Jul 25, 2003 07:46 PM
ITR#00-1077
May 21, 2002 01:03 PM
