Ls vtec tend to blow?
I'm planning to buy this blow off of someone...it's an ls block bored out to a 2L...with forge high compresson pisont that's suppose to yeild 12.1 compression...I have a gsr that i want to put on top of it..with stage 2 cams. I want to see 9 with this set up..do you guys think it'll blow...??of course it'll be tuned...
9 what?
could it be 9 min, 9 hour, 9whp, 9bhp, 9psi of boost, 9 birds or 9 seconds.
if it is timerelated(still talking about the 9), in relation to what?
maybe
9 min 1/4 mile?
9 second 1/8 mile?
9 hour mile?
confuseddd
maybe
9 min 1/4 mile?
9 second 1/8 mile?
9 hour mile?
confuseddd
haha..funny guys....Blows up as in blowing a motor apart....9's meaning i want to see 9 grand....but yah...i dont want to spend 1000 on a built block with out no sleeve and blow it...i have the head set up already...It's an LS block bored to 2L with forge piston yeildin 12.1 compression...so i thought the block itself would be kind of weak..
well you thought wrong the b20 is the weaker block with a sleeved ls you should have fun just change to some stronger rod bolts like from arp and you should be fine
the things is....the Ls block is not sleeved.....so i thought it would be pretty weak if it's bored out....fo and ls block...i knew b20 were easy to blow..cause i seen them blow left and right...but for a Ls bored to 2l's...worries me.
A stock LS sleeve bored to 84mm with 12:1 compression is by far stupid. The piston walls are way too weak and it wouldn't last. if the block were sleeved then it would be fine, but that much of an over bore on stock sleeves is past pushing the limits. -Jason
in another thread i asked this already, but since you mentioned. b20 tend to blow
i tought b20's where stronger due to the closed deck setup
? because people use them for mild boost apps i tought it might be a cheap/reliable setup for a destroked(87.2mm) frankenstein on juice(100-150shot maybe?)
. that would spare me the costs of sleeving, boring and honing
, any tougths on this one?
?i tought b20's where stronger due to the closed deck setup
0verd0sed_DC
Mar 13, 2007 11:54 AM
