Emission Test tomorrow!!!
89 CRX HF with D15B2
The Check Light doesn't work but they don't care.
What do you think? I changed my catalytic converter with my entire exhaust, O2 sensor, oil, and spark plug. Also used V POWER to clean the vacuum, and guarantee to pass emission.
The first time I didn't even get the word FAIL, but received a GROSS POLLUTER!!!!
Modified by FOMULA91 at 1:05 PM 3/30/2005
lol at gross polluter... i just got my hatch tested saturday
passed, but the testers did a full test on my car. had to wait longer than others. maybe he saw me smiling when he stalled in my car
good luck
good luck
Hmmm....what were the numbers from the test? That will help narrow the problem. I would set the timing to stock and replace the cap and rotor for the distributor. It could also be the PCV system but I can't be sure without knowing the test numbers.
Gross Polluter doesn't mean the CAT IS BAD!!
stock cats last forever
I just pay like 250 so I know my car passes grantee pass
so I don't have to deal with BS how much is chaning at cat now days like 100buck lol..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 »</TD></TR><TR><TD CLASS="quote">89 CRX HF with B15B2 </TD></TR></TABLE>
i thought alll CRX's were D series? or if its b series i have never head of a B 15, can someone tell me whats up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblkCR-X »</TD></TR><TR><TD CLASS="quote">
i thought alll CRX's were D series? or if its b series i have never head of a B 15, can someone tell me whats up?</TD></TR></TABLE>
there are only D15b2, this guy either lost his mind or mispelled...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si »</TD></TR><TR><TD CLASS="quote">there are only D15b2, this guy either lost his mind or mispelled...</TD></TR></TABLE>
Sorry for misspell.
And **** because when I was about to test my CRX, the antifreeze started to leak (the hose cracked). Then it started to spray all over the place!!!!
I was like holly **** but I was lucky that this happened in SWC automotive section because the technician helped me. I then called my twin bro to pick me up to go buy a new radiator hose and the clumps. Everything else went fine after that but I needed to reschedule my emission test to Monday.
Sorry for misspell.
renelimabr85
10
Feb 19, 2010 10:35 PM
crx00
Aug 6, 2003 06:37 PM
