Greddy turbo kit, car dies after 5 sec of idling
Old Mar 29, 2005 | 09:03 PM
SpoonFull's Avatar
Default Greddy turbo kit, car dies after 5 sec of idling
I recently put on my greddy turbo kit, i hooked everything up, fmu and stuff,, but the car would die after 5 seconds of idling.
how does the FMU hook up to the map sensor? we connected the green wire to the ecu and plugged into the female connector on the green wire to the white wire. is this properly done? or is there a correct way?
Old Mar 29, 2005 | 11:17 PM
SpoonFull's Avatar
Default Re: Greddy turbo kit, car dies after 5 sec of idling (SpoonFull)
is -18psi a possible vacuum leak?
what is the throttle body water bypass hose that greddy speaks of?
Old Jul 19, 2005 | 09:40 AM
ev0luti0n's Avatar
bump for some knowledge.
Old Jul 28, 2005 | 09:08 AM
Integra_RS's Avatar
check your spark plugs
Old Jul 28, 2005 | 09:25 AM
Boltz's Avatar
Default Re: (Integra_RS)
seeing as you've already mentioned the map sensor, I will almost gaurantee thats your problem. Thats exactly what will happen if you dont have your map sensor hooked up.
Old Jul 28, 2005 | 10:00 AM
blaze the chemi's Avatar
Default Re: (Boltz)
The green wire is to connect to the MAP going to the ECU. The white wire is to connect to the MAP wire going to the sensor. Do not connect the green to the white. Make sure you have those male/female connectors covered from metal interference.
Gant
May 18, 2005 08:47 PM
Boosthead
Jan 5, 2005 10:45 AM
Ski11z
Jul 15, 2004 08:36 AM
chomorro
Jul 28, 2003 11:12 PM
vtectuner99
Aug 30, 2002 12:34 AM
