Making own custom pipes, how to bead roll?
Im making my own piping but not to sure what you guys do for the bead rolling. Can i just put a nice bead of weld around the pipe? I mean the coupling makes the seal correct the roll is only to stop it from blowing off. Please correct me if im wrong. Thanks in advance
You can lay a bead around the entire pipe or just do a few spots(what I did). By spots I mean like one spot at 12, 3, 6, and 9 o'clock positions.
Phil
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">You can lay a bead around the entire pipe or just do a few spots(what I did). By spots I mean like one spot at 12, 3, 6, and 9 o'clock positions.
Phil</TD></TR></TABLE>
Yup, this is what I would suggest...
Just put tacks around the edge of the pipes... my buddy put 4 on each end at 3, 6, 9, and 12... holds great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">you can weld a spot on the inside tip of some vise grips and go aroung clamping a little bead roll, I did it that way.</TD></TR></TABLE>
That's a crafty idea - I like it
C-West Civic
Jan 31, 2005 04:20 PM
