few questions EJ-9 D14
hello everybody
i have questions about my cay...
when i turn the key to on position the lights on the cluster shows the oil,battery and handbrake light, is that ok that the oil light is on?
how can i check if my o2 sensor is fucked without a cel check ?
best regards moshik galimidi
i think this question is kinda stupid, think about it. would they put a light in the cluster if it wasnt important. it means u have low oil pressure and yes its ok if u want to blow your motor. checking for a cel takes like 2 mins, but u would know if it was bad cuz your car would run like **** and u would get terrible gas mileage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">i think this question is kinda stupid, think about it. would they put a light in the cluster if it wasnt important. it means u have low oil pressure and yes its ok if u want to blow your motor. checking for a cel takes like 2 mins, but u would know if it was bad cuz your car would run like **** and u would get terrible gas mileage</TD></TR></TABLE>the reason i'm asking this is because i cant find the lil' gray plug..... and belive me i searched.
can i check the o2 sensor with a voltmeter?
if your o2 sensor were messed up you would geht a engine check light in your cluster.
it's normal that all lights went on when you put in the ignition, that is called a self-test if that all bulbs are working...
crew08 (girlygirlracer)
23
Mar 24, 2005 02:54 AM
