GSR Gauges in Si cluster swap even possible??
Old Mar 29, 2005 | 12:40 PM
519[H]Si's Avatar
Default GSR Gauges in Si cluster swap even possible??
I recently (today) picked up a GSR cluster from the wreckers and i wanted to swap the gauges into my Si Cluster..
Q.#1 : Is this swap even possible ?
Q.#2 : How do you take off the speedometer and all other needles ?
Q.#3 : I dont have a Low Fuel sensor in the gauge cluster but the GSR one does. My question is if its possible to use this sensor in my Si cluster ?
Old Mar 29, 2005 | 01:01 PM
BlueIntegraBoy's Avatar
Default Re: GSR Gauges in Si cluster swap even possible?? (EH2_519)
The question is why. The gauges won't fit into the EG housing. The gauges faces aren't the same size. You need an Integra fuel pump if you want the low fuel indicator.
Old Mar 29, 2005 | 01:22 PM
519[H]Si's Avatar
ok soo this isnt possible at all ? What if i modified the GSR faces to fit the EG housing ??
And main question That i need to know cuz i wanted to paint the needles.. HOW DO I TAKE THEM OFF ?????
Old Mar 29, 2005 | 01:59 PM
komat's Avatar
Default Re: (EH2_519)
the gsr cluster fits into a eg u just have to trim the dash or cluster alot to make it sit clean
search theres been couple diy on it
Old Mar 29, 2005 | 02:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH2_519 &raquo;</TD></TR><TR><TD CLASS="quote">ok soo this isnt possible at all ? What if i modified the GSR faces to fit the EG housing ??
And main question That i need to know cuz i wanted to paint the needles.. HOW DO I TAKE THEM OFF ????? </TD></TR></TABLE>
What color are you going to paint them? Use a fork and gently pry up on the needle to remove.
crazy_ls_90
Jul 2, 2008 12:50 PM
Circa
Jun 9, 2006 10:59 AM
msinsky14
12
Mar 1, 2006 07:36 PM
sheBangZ
11
Oct 27, 2005 12:10 PM
ME SO FST
Jun 2, 2005 07:31 PM
