how to set ignition timing with increased idle RPM??
i'm sure there are many people out there who have somehow raised the stock idle from 750 to 800-900rpm when trying to smoothen out the idle due to high lift/duration cams.
question is how do you set the base timing when the idle is no longer 750rpm?
setting the timing at 16deg@750rpm would probably be diffrent then the timing at 16deg@900rpm....... am i right or wrong?
lets say i had my engine to idle at 900rpm. what would i have to set the timing gun to to acheive a base timing of 16deg??
thanks
thanks
connect a piece of metal (paperclip) to the brown and black connector with the clip
that connector can be found on the passenger side above the ECU. Their tucked away.
