How long did your B18C1 swap take?
Old Mar 29, 2005 | 11:01 AM
Vbp6us's Avatar
Default How long did your B18C1 swap take?
I am curious to see how long it took for a complete swap to take place in any '93-'95 hatches out there.
Days? Weeks? Months?
Here is a question which I know I could find the answer to by searching but since I've made a thread, someone could answer it too. Were new engine mounts needed or are stock mounts ok?
thanks
Old Mar 29, 2005 | 11:03 AM
Kyles ej1's Avatar
Default Re: How long did your B18C1 swap take? (DB8D)
ive been waiting for like a yr and i think it will be a few more months
Old Mar 29, 2005 | 11:07 AM
EVIL Hx Coupe's Avatar
It took me 3 and a half days to install mine in my 96 coupe which is kinda more work because of the differently designed harnesses.
Thats including taking out the old motor, and changing the clutch on the newone. It was my first time swapping and I did it all by myself. The only problem I ran into was the motor wouldnt crank when I first tryed it, but it was the stupid tranny ground, and I also cracked my old radiator pulling out the old motor.
Old Mar 29, 2005 | 11:19 AM
b204dr's Avatar
me and 3 people swapped a 95 gsr engine usdm into a 95 vx hb in 5 hours - 1 hour to pull 4 hours to install
Old Mar 29, 2005 | 11:53 AM
Honda Bull's Avatar
Default Re: (b204dr)
Searching for B18C1 - 2.5 years
Making transaction for B18C1 - 1 week
Waiting for the right time to put it in - 7 months
Install time - probably 2 days
The smile you get from planting the throttle - PRICELESS
But this is me and most people that buy a motor slap it in the next week. Oh well.
Old Mar 29, 2005 | 12:00 PM
mingbling96's Avatar
Default Re: (HondaBullSQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaBullSQ &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, the price of that is 2.5 yrs and the money used to buy the gsr motor and time spent to install it.
Old Mar 29, 2005 | 12:05 PM
Hatch'd's Avatar
Default Re: (mingbling96)
my buddy di the b16 swap in to a 92 si hatch in about 6 hour in my driveway by him self
Old Mar 29, 2005 | 12:06 PM
Evil_Wizard's Avatar
Default Re: (Hatch'd)
Did mine in about 4 hours.
Who Said's Avatar
3 1/2 hrs total. old motor out new motor in.
i work in a shop.
Old Mar 29, 2005 | 12:29 PM
hatchi's Avatar
First swap i did it took 6 hours in and out and it fired up with no codes. after that it takes only between 2-4 hours considering if there are codes
Old Mar 29, 2005 | 12:34 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How long did your B18C1 swap take? (Who Said)
Yea man. I had my motor out, replaced the block, cams, timing belt and a few other things and back in and running in 8 hours. If you know what your doing, it takes no time at all. With the right tools of corse.
Old Mar 29, 2005 | 12:37 PM
hatchish's Avatar
depends on how many swaps ur doing what distractions get ur way and what goes wrong also not having the right tools one thing to remember is when u run into a problem dont get all pissed just look at all posibilitys before quiting oh yeah buy cotter pins and make sure u take advantage of auto zone's free tool rentals
Old Mar 29, 2005 | 12:55 PM
JDMallTHEway's Avatar
Default Re: (hatchish)
5 hours in the parking lot at 3 in the mornin.
Old Mar 29, 2005 | 01:10 PM
delslo93's Avatar
Default Re: (JDMallTHEway)
If you dont know what you are doing and are a first time i think it will probably take a good 8 hours or more. Plan on a good full saturday if you arent used to doing these things. If you know what you're doing then probalbly only a few hours. I've done one in 4 hours before. And yes you can reuse the stocke C1 mounts but new ones are always better than used.
Old Mar 29, 2005 | 01:54 PM
debo*'s Avatar
Default Re: (delslo93)
im actually in the process of mine (GSR going into a 95 civic dx hatchback) and it took me about 2 hours to pull my d15b7 out, and probably looking at 8 hours putting the swap in, ran into some mount problems, needed a AC bracket modification, and had to rewire the harness with a few new wires, also installed a new suspension (ground control/koni yellows/eibach) and exhaust system. im just waiting on my header, once thats here which should be today or tommorow, i can fire her up, started this friday. ill reply to this once mine is up and running and possibly show you guys some pics
Old Mar 29, 2005 | 02:03 PM
pushthegashitafatass's Avatar
9 hours 13 mins 22 secs i timed myself
Old Mar 29, 2005 | 02:16 PM
lazynok's Avatar
Default Re: (pushthegashitafatass)
three days with NO engine hoist and ONE hydrolic jack. its hell i say
its so much easier with a hoist... but my neighbor was on vacation so i couldnt barrow it =[ doing a d16y7 swap was freakin' a breeze with a hoist...
Old Mar 29, 2005 | 02:23 PM
egvtec's Avatar
3 hrs gsr out for clutch and back in with new one
Old Mar 29, 2005 | 05:50 PM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, the price of that is 2.5 yrs and the money used to buy the gsr motor and time spent to install it. </TD></TR></TABLE>
Did you really have to ruin it.
Old Mar 29, 2005 | 06:04 PM
97crxdelsol's Avatar
it all depends.... if u have all the parts needed with u it should be a quick one.... mine took a full day.
Old Mar 29, 2005 | 07:15 PM
bboylito's Avatar
see this is what you need to understand, the labor to actually put in the motor doesnt take long at all,
its the things your missing or fixing that take a toll on you
for instance i had to change a clutch change the short shifter, wait for parts to come in, broke some things in the process and stripped some nuts so had to get new ones
but after having the motor ready and setup to install it shouldnt take you more than 5-9 hours to put it in
worry more about the parts you are replacing and make sure you have all the tools you need because searching for tools or jacks really slows you down
Old Mar 29, 2005 | 07:32 PM
deviant1's Avatar
Default Re: How long did your B18C1 swap take? (bboylito)
you guys rock it took me a full day just to install an axle but at least i learned how to do it right.
fuzzysig
K Series
Dec 8, 2017 08:26 PM
808EK4
16
Jan 21, 2009 09:57 AM
DEJ203
Jul 17, 2008 07:46 PM
CivicSwapper
Sep 1, 2006 07:41 AM
Addijhaq
Apr 24, 2005 07:27 PM
