Confirm brake bleed bolt size
Can anyone confirm the brake bleeder size? I searched and came up with 8mm. But i want to make sure it is 8mmx1.25.
I looked on summit racing and they have both 8 and 10mm listed, and they say 10mm is for honda.
On my LS, its 10mm all around.
For Russell speed bleeders, they listed a 8mm for the rear calipers, which was wrong and the bleeders feel into the hole.
Ok searchd around the web a bit and came up with this. http://www.buybrakes.com/russell/apps-Acura.html
It looks as though the front is 10mm and the rear is 8mm. Kinda makes sense as the rear is a smaller caliper!
10mm is the thread.
Do NOT buy the 8mm. I have a set right here and they are TOO SMALL They use the same size one on the rear as the front. I made the mistake already.
The Russell application chart IS WRONG
Cause of the mistake, I took the new bleeder that came on the front rebuilt caliper and put them on the rear calipers and only installed the speed bleeders on the front.
trecool44
May 22, 2009 09:42 AM
RedGSR
Jun 3, 2004 09:08 PM
