Throttle Cables
Old Mar 29, 2005 | 08:44 AM
ferio 95's Avatar
Default Throttle Cables
Ive been searching all around but havent really found what im looking for. To the point. Ive noticed people making alot of custom manifolds that dont really mount the throttle rotor in a stock placement or just putting the throttle body itself in a position to where a stock cable wouldnt be long or short enough. so what im asking is does anyone offer custom throttle cables or kits to make your own?
Old Mar 29, 2005 | 09:12 PM
Syner-G-Racing LLC's Avatar
Default Re: Throttle Cables (ferio 95)
Lokar sells custom cables. thats what I used atleast
Old Mar 30, 2005 | 05:36 AM
ferio 95's Avatar
Default Re: Throttle Cables (Syner-G-Racing)
will they be designed like a stock cable? or do you have to specify a length?
Old Mar 30, 2005 | 01:22 PM
you just cut it to length...one end is fixed to hook up to the pedal linkage and the other has to be cut and crimped just call lokar and they'll hook you up
Old Mar 30, 2005 | 06:21 PM
lohatch's Avatar
summit racing sells lokar throttle cables and you can order then in a couple different lengths, and then modify them to your application.
Old Mar 31, 2005 | 01:53 AM
Default Re: Throttle Cables (lohatch)
thats actually where I bought mine.
Old Mar 31, 2005 | 02:36 PM
Ca$h's Avatar
Are these the ones you all are talking about? This style is the only thing I can find on Summit under Lokar, Universal throttle cables. These appear to be preassembled so either they aren't the correct cables or they can be disassembled, cut and reassembled.
DDTECH
Aug 13, 2013 02:45 AM
wade
Mar 18, 2009 01:14 PM
neo_
Feb 15, 2009 11:10 AM
NatrualAsp VTEC
Sep 17, 2003 05:19 AM
