car is missing dont know why~!! cant fix
hey guys thanks in advance. i have a 88 crx and my car has a slight miss and you can really tell at low rpm in high gear at about 20% throttle
i have replaced with oem parts
plugs
wires
cap
rotor button
coil
and ignitor and i cant figure out the problem
i tried searching but with everyone it was one of these problems. let me know if you have any ideas
plugs
wires
cap
rotor button
coil
From: I told you to wait in the truck in Texas, United States
Looks like you have covered
most all of the electrical stuff so how about fuel delivery?
Clogged fuel filter,
Clogged or "dead injector"..
my distributor on my d16a6 was shot and it would predictably miss around 2200 rpm every time i drove it. replaced the distributor and problem fixed. ecu was throwing code 9.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">Looks like you have covered
Clogged or "dead injector"..</TD></TR></TABLE>
He mentioned at a certain rpm, that would be happening throughout the entire rpm band. But do those things anyway for maintanence.
Also, do you have any codes?
If your valvetrain is loud then you should probably just adjust the clearance which only takes about a half hour to do and if it doesn't fix the problem at least thats one less sound you have to hear from your car.
BullmoosinRex
Feb 13, 2019 02:10 PM
