Suspension & Brakes Theory, alignment, spring rates....
lowering help!!
Old Mar 29, 2005 | 01:07 AM
allsho's Avatar
Default lowering help!!
Alright me and a buddy worked on my car for looongg tonight..
its a 88 4door ..civic
we lowered 3 out of 4 corners...
the 4th one .. the bolts under neath just kept turning and turning to come off.. but wouldnt grab on anything.. making it so we couldnt get it GOING.. ya know?..
it was really weird.
anyone know what I am talking about?? and any help??
THANKS!!
:smile:
ALSO
Me and a buddy did the coils on my car today...
now, when we did the rear (its a 88 civic 4 door)..
the middle of the shock has that protector on it to block the dirt/crap from going onto the bar that compresses...
we took off the protector because the coil wouldnt go down without it gone...
now from what I REMEMBER the shocks should still be good to go without that protector thingy .. right?
if not, we gotta jack it up and some how make a protector for them ....
any ideas???
right now they look like this
without the protector u can SEE the metal behind the coil
Modified by allsho at 2:24 AM 3/29/2005
Old Mar 29, 2005 | 04:27 AM
allsho's Avatar
ok we got stuck on the bolt that the strut is attached to in the driver side rear....
there are 3 bolts total holding the strut in place... 2 in the trunk and 1 big **** in the bottom, control arm or whatever......
we got the nut off of the inside end, but the screw is still in there and just wont come out....... it spins, and we have tried tapping it through the other side.. and nothing....
weve used impact, breaker bar, everything... and it spins and wont come OUT..
it makes no sense and its just frusterating.
Old Mar 29, 2005 | 06:12 PM
JDMotive's Avatar
Default Re: (allsho)
if your talking about the bolt that attaches the lower arm to the shock then you sould try to jack up the arm and hammer the bolt out. the only reason that the bolt isn't coming out would be that it is binding under pressure from the suspension being fully extended but it should hammer out easy. hope that helps you
dopamean
Sep 28, 2009 06:11 PM
happyabortion
19
May 5, 2009 03:25 PM
allsho
Mar 29, 2005 06:19 AM
2000fbp
11
Jul 10, 2003 10:42 PM
Si-Yaaa!
14
Jan 8, 2003 03:40 AM
