engine bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew »</TD></TR><TR><TD CLASS="quote">cheapest rod bearing u'll find: ACL's
http://www.autohausaz.com/cata...16872</TD></TR></TABLE>
those are the cheapest... but from what i hear nothing beats oem.
LOL! Those are CHEAP!
I wonder how they perform?
I'm using a $50 set of bearings for the engine I rebuilt.
I should have spent real $ and got OEM parts like the rest of the engine, but $200 for bearings was out of my budget at the time.
$50 bearings still holding strong after 5,000 miles or abuse!
dont just order bearings......If you cant plastiguage it to get the right size OEM bearings....Take it to a machine shop and have them assemble it.
If you dont find out exactly what clearance bearing you need you are going to have trouble in the long run.
Do it right the first time soo you wont have to rebuild it again after 5000 miles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew »</TD></TR><TR><TD CLASS="quote">cheapest rod bearing u'll find: ACL's</TD></TR></TABLE>
How are the ACL's... Do they hold up like OEM? Any experience's with them (good or bad)? and anyone boosting on them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboLSef »</TD></TR><TR><TD CLASS="quote">How are the ACL's... Do they hold up like OEM? Any experience's with them (good or bad)? and anyone boosting on them?</TD></TR></TABLE>
I'm running ACLs in my built LSVTEC...
ACLs are great bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen »</TD></TR><TR><TD CLASS="quote">dont just order bearings......If you cant plastiguage it to get the right size OEM bearings....Take it to a machine shop and have them assemble it.
Do it right the first time soo you wont have to rebuild it again after 5000 miles</TD></TR></TABLE>
really, that sucks i was looking forward to assembling this myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula »</TD></TR><TR><TD CLASS="quote">
really, that sucks i was looking forward to assembling this myself. </TD></TR></TABLE>
You can assemble it yourself.
I did... in my garage.
Just plastigauge and learn up on how to read the rod clearances in a Helm or Service manual.
It's not hard to do at all.
Once you have everythign worked out then you can order a set.
"Universal" type bearings that come in a pack are are about the same size. They won't make it to specific 100% tolerances, but they should fall within the factory tolerance somewhere. Some will be on the high end and some on the low end of the tolerance depending on your motor.
honda stamps a number on the crank if you take that number into the dealership the will give you all the right sized bearings for that motor but i would still paltigauge it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex »</TD></TR><TR><TD CLASS="quote">honda stamps a number on the crank if you take that number into the dealership the will give you all the right sized bearings for that motor but i would still paltigauge it </TD></TR></TABLE>
Those tell you what came in there orignally.
Over years of use, wear and tear, and especially if you change out parts (if you change out rods or the crank) then you MUST plastigauge.
1badITR
Aug 23, 2002 01:34 PM
