crx check light is on
Old Mar 28, 2005 | 04:01 PM
lilsaigon510's Avatar
Default crx check light is on
i need help!! my check light is on and i wanted to kknoow how to turn it off.....now the lights is one, and went i give it as its seems like it weaker and is bloggin some how...my not sure wats wrong wit it....it happen when i was in first gear and i rev it pretty high and i skirt in second gear... after i did that the light went...help me please....thanks alot guys.
Old Mar 28, 2005 | 04:06 PM
EP3_05's Avatar
Default Re: crx check light is on (lilsaigon510)
Pull up the carpet in the passenger footwell and look for a brass colored plate. There should be a little window there with a blinking led. Count the flashes:
i.e.
1 short flash=1
1 long flash=10
It should be a repetitive cycle.
For example code 11 would be
1 long flash 1 short pause 1 long flash 1 short pause etc
Report back with the code and we should be able to help you out.
Old Mar 28, 2005 | 04:10 PM
Default Re: crx check light is on (91civic)
ok i checc the light....it did like 9 fast flashes and it paused. then 9 time again then it pause.....can u help me wit the problem? thanks alot
noood
Jan 18, 2008 06:22 AM
vtec-adykt
Feb 10, 2005 10:49 AM
gotfingers
11
Apr 27, 2003 04:05 PM
CWITR
Mar 4, 2002 12:25 PM
