Question on EZ Charge
First off, my car is a 2000 Civic and the a/c isn't running cold anymore
So I bought one of those R-134a Refrigerant cans to recharge my a/c. It says to pump it into the low-pressure port of the a/c... which pipe is that?! I see 2 pipes with blue caps when I pop the hood. Right in front of the engine above the a/c. Are those the ports? One that has a "L" on the cap and the other has a "H" on it. The "H" pipe is the closer one to you if you're standing in front of the car. Which pipe is it? HELP?!
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Dude are you serious?
Yes the Cap with the L stamped on it is the low side of the system. I'm curious though, does your refill kit come with a gauge? if it does watch it closely and try not to get any refrigerant on yourself.
Sorry about the doublepost
