Removing rear seat to check fuel pump
Old Mar 28, 2005 | 11:28 AM
Bird333's Avatar
Default Removing rear seat to check fuel pump
I got a 88 civic hatchback and according to the service manual I need to remove the rear seat to check the fuel pump. Are there any short cuts to removing the rear seat to check this? I mean, do I have to remove the backs also? Any tips/shortcuts would be appreciated.
TIA
Old Mar 28, 2005 | 11:32 AM
bostoncal's Avatar
yes, you have to remove the back seat first, then remove the bottom seat. no short cuts, just do it right the first time and you wont have any problems. dont forget to remove your negative battery terminal first before messing with the fuel pump.
Old Mar 28, 2005 | 11:33 AM
DJ_SaNdOz's Avatar
Default Re: (Este_Cara)
or you can do like me & drop the whole damn gas tank b/c you didn't realize there is a service panel in the car
Old Mar 28, 2005 | 11:42 AM
Luserkid's Avatar
Default Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">or you can do like me & drop the whole damn gas tank b/c you didn't realize there is a service panel in the car </TD></TR></TABLE>
Wow i bet you were beyond pissed.
Its really easy to pull the seats in Civics, just a couple bolts and its off.
Old Mar 28, 2005 | 11:55 AM
DJ_SaNdOz's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Its really easy to pull the seats in Civics, just a couple bolts and its off. </TD></TR></TABLE>
Yeah, I realized it as I was putting the gas tank back on...needless to say, I used some explitives to describe the situation.
JDMCRX
Feb 4, 2009 07:23 AM
Steve LeB
May 12, 2007 02:35 PM
Joeyt426
Aug 1, 2006 01:55 PM
LsTurbo91
Mar 19, 2005 07:06 PM
JeremyL
Jan 7, 2003 09:50 AM
