few LS vtec questions
Old Mar 28, 2005 | 11:19 AM
Grand's Avatar
Default few LS vtec questions
i have a b18a block and a 1st gen jdm b16 head i think im gonna buld an ls vtec but i have a few questions first
what type of parts do i use for the following list
head gasket
timing belt
oil pump
are pr3 pistons good to use for higher compression
also is the golden eagle sandwich plate kit worth buying
Old Mar 28, 2005 | 11:29 AM
butters's Avatar
Default Re: few LS vtec questions (LG_R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18a block and a 1st gen jdm b16 head i think im gonna buld an ls vtec but i have a few questions first
head gasket
timing belt
oil pump
also is the golden eagle sandwich plate kit worth buying </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Which timing belt you run depends on which water pump you have. The oil pump is driven by the crank, and does not affect your timing belt choice.</TD></TR></TABLE>
also, look into the GE ls/vtec conversion kit. it includes oem head gasket bored to your prefrence. Pr3's or P30's are a good oem choice to raise your compression. Try searching the archives. There are countless topics on ls/vtec build ups
Old Mar 28, 2005 | 12:36 PM
Grand's Avatar
so it doesnt matter what water pump i run
i have also heard i should use a b series vtec oil pump and windage tray is this true
Old Mar 28, 2005 | 12:37 PM
Grand's Avatar
also roughly what compression ratio will i have with pr3 pistons and a b16 head
Old Mar 28, 2005 | 02:00 PM
butters's Avatar
Default Re: (LG_R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">also roughly what compression ratio will i have with pr3 pistons and a b16 head </TD></TR></TABLE>
use this to figure out est. compression http://www.c-speedracing.com/h...c.php
and yeah just use a gsr oil and water pump.
e she i
Nov 19, 2006 04:09 PM
boosted92hatch
May 29, 2006 08:44 AM
GEN2INTEG619
Mar 24, 2005 07:17 PM
elusive123
Jul 18, 2004 11:06 AM
biggdogg
Aug 31, 2003 12:03 AM
