dpfi to mpfi?
Old Mar 28, 2005 | 08:57 AM
tissimo's Avatar
Default dpfi to mpfi?
hey all.. I got a 90 civic ex but the body is in bad shape. I'm thinking about getting a 88 DX 4 door that has a better body. But want to swap the mpfi stuff to the dx. But also want to swap the dpfi stuff to the ex so i can turn around and resell it for like 200$ or something. I plan to swithc the trannys and everything over. Do i need a conversion harness or something? Can I just swap the firewall to ecu harness from car to car? or do i have to get a rewiring kit or something?
Old Mar 28, 2005 | 09:13 AM
tilt's Avatar
Default Re: dpfi to mpfi? (tissimo)
you will need to repin/rewire the dizzy and ecu and injectors. do a search on mpfi and you will see several how-tos on it.
Old Mar 28, 2005 | 09:15 AM
tissimo's Avatar
yea ive looked over the how-tos.. what about MPFI to DPFI?
Old Mar 28, 2005 | 09:16 AM
shivern's Avatar
Default Re: dpfi to mpfi? (tilt)
Lots of wiring that you'll probably have to do within the engine bay, soddering all that **** aint easy , but definately worth it
Old Mar 28, 2005 | 09:29 AM
Rywire's Avatar
Default Re: dpfi to mpfi? (shivern)
You can get your wiring done through us... http://www.rywire.com
We offer the fastest turnaround, cheapest prices, and will transform your dpfi harness into a sleek clean mpfi harness...
Give us a call.
Ryan
Old Mar 28, 2005 | 09:32 AM
tissimo's Avatar
you cant just swap the whole harness ecu to engine over? why hasn't anyone done this... Rewiring is easy.. I've rewired 1/2 a mkiii turbo harness, and am in the middle of extending my 1jz harness 18" so itll work with lhd..
Old Mar 28, 2005 | 10:33 AM
NikoZai's Avatar
Default Re: (tissimo)
We can do both conversions for you, EX to DX is fine.
Think of the EX to DX this way, for a DPFI to MPFI we would add 4 wires, so for the reversed swap, you want to pin the distributor without the Cylinder position wires, and the injectors without 2.
For the injectors you would make pins A1 and A3, tie together at the ECU (Primary Inj) and for pins A5 and A7 do the same. (Secondarys)
Now i would take the pins from A3 and A7 and tape them off for later use basically.
At the injectors its a little tricky, we would put the DX plugs on it so it's plug and play. Also tape off the extra distributor wires for later use.
There are ECU pins at B and C plug that need to be moved around.
Take the MPFI directions and read them backwards
We can do the MPFI to DPFI for $100, it won't be much work.
Old Mar 28, 2005 | 12:01 PM
dr_latino999's Avatar
Default Re: (NikoZai)
If you are going to have the 90EX and the 88DX sitting around why not move EVERYTHING over, I.E. Engine, Drivetrain, Suspension, Interior/Engine Harness, Dash, it'll be like you never left the EX.
Old Mar 28, 2005 | 12:46 PM
tissimo's Avatar
Default Re: (dr_latino999)
thats what im wanting to do.. I dont see why i can just swap the whole harness.. then engine harness and the firewall harness over to the new car.. but no one says anything about it.. I guess ill mess with it and see
Old Mar 28, 2005 | 12:52 PM
EP3_05's Avatar
You can swap the harnesses as long as you swap everything. By that I mean the engine harness and all of the interior harnesses.
Old Mar 28, 2005 | 01:12 PM
tissimo's Avatar
Are the interior harnesses different for ex and dx? Like the dash harness/ fuse box harness and what not? how many would I have to change?
Old Mar 30, 2005 | 08:43 AM
Rywire's Avatar
They are different if the year changed... 88 and 90 are different controls
Old Mar 30, 2005 | 11:59 AM
crxdonwon's Avatar
after you get the dash out it's not that bad it's just taking everthing out that's a pain in the ***! If you can swap the motor and trans, then you can do this.
Have fun!
kaddi88
Mar 29, 2008 04:34 PM
Slowass2dr
Jan 12, 2007 11:43 AM
91crx but i heard vtec
Jan 16, 2005 08:30 AM
Layziebtnh055
Mar 29, 2004 11:03 AM
Dancing is Forbidden
Jan 23, 2003 06:39 AM
