DA 2ng gen and DC2 3rd gen Front brake caliper differences
Old Mar 28, 2005 | 05:44 AM
Redline96LX's Avatar
* B A N N E D *
Default DA 2ng gen and DC2 3rd gen Front brake caliper differences
I got a set of calipers from a 1988 Honda Accord LX-i which are the same as those from a 1990 Acura Legend and those of a 90-93 Integra. The calipers DO mount on a 99-00 Si knuckle, just like 94-01 Integra calipers would. They are however not identica and take different pads. They do mount with the pads and knuckle on tho, and I believe I can use on my 96 LX with the SiR knuckles, DA calipers, and 96-00 EX rotors. My question is, after the mounting points, the 57mm bore piston that the DA and DC calipers share, is there a difference in braking? is one stronger than the other? I know the DA uses a pad spring, and that the DC2's side retainer springs for the pads are a little different shaped. They look to take the same brake line fitting as Ive fitted the one from a 99 SiR on these calipers. Anyone know the difference in power? like someone with a DA with DC calipers, or vice versa?
Old Mar 28, 2005 | 12:41 PM
vactor's Avatar
Default Re: DA 2ng gen and DC2 3rd gen Front brake caliper differences (Redline96LX)
bump. mike is a good guy!!
Old Mar 28, 2005 | 12:56 PM
Jasper_db1's Avatar
The calipers themselves are the same or very similar. The DC2 bracket lets you use the larger and more available DC2 pads.
Old Mar 28, 2005 | 01:57 PM
* B A N N E D *
Default Re: DA 2ng gen and DC2 3rd gen Front brake caliper differences (Jasper_db1)
the DC2 pads are more expensive may I point out though. most say go with the caliper to choose pads, but your right, the shape depends on the caliper bracket, since the caliper simply grabs and uses a circular piston
Modified by Redline96LX at 8:51 PM 3/28/2005
Old Mar 28, 2005 | 09:11 PM
* B A N N E D *
ttt.
it seems the DA and DC have a close to similar caliper, but the mounting brackets are different, which use the same mounting points to a knuckle, but different retainer sprinfs and shape, thus allowing larget brake pads.
Old Mar 31, 2005 | 08:46 PM
* B A N N E D *
Verified.
Brake pads are NOT dependant on calipers. They are dependant on the CALIPER MOUNT BRACKET. This dictates the shape of the brake pad you buy.
Old Apr 3, 2005 | 10:45 AM
* B A N N E D *
bump for a final answer on tegra calipers?
Old Apr 3, 2005 | 12:11 PM
* B A N N E D *
ttt
Old Feb 13, 2006 | 08:22 PM
* B A N N E D *
bump from the dead to finalize my own question.
Both DA (90-93) and DC (94-01 not R) calipers are stamped 17CL14VN. Both take a 57mm piston, the DC takes a larger brake pad. The brackets are not the same, calipers do not bolt onto the other bracket (DA caliper body on a DC bracket does not fit).
KcAccord
Jul 23, 2017 01:55 PM
nightscream
Apr 22, 2012 11:17 AM
h23prelude
Dec 8, 2008 10:43 AM
mdixonjam
Apr 17, 2005 08:11 AM
JBB194
Jul 2, 2003 05:55 AM
