nitrous tech.
help me out here. last time i had my dry nitrous kit on, i blew my head gasket. it was only a 60 shot. yes i used it alot in one night but can someone tell me how far away from the TB the nozzel should be cause i think thats what caused it. thanks
thanks man. yeah youre right, i think it all went straight back to the farthest cylinder (4? maybe 1) and went to poo poo from there. thanks for the help!
For dry NOS kits I recommend about 10 to 12 inches away from the throttle body because this will let the NOS distrubte easier to all 4 cylinders. For wet kits I recommend you place the fogger no further then 5 inches away from the throttle body because you are mixing fuel along with the NOS. If its stuck too far away you have a chance to freeze the throttle plate open and also if the fogger is too far away you actuall get more NOS then fuel, an uneven mixture which will lead to detonation.
I try to place a dry kit between 12 and 18 inches away from the throttle body. Only bad side of it is it's take a couple seconds for the nitrous to hit. It seems to disburse of the nitrous well tho.
Duck Sauce
Dec 16, 2001 10:35 PM
