just bought 1992 GSR need help
I just bought a 1992 gsr and im having some problem.One the front wiper does not work,but the rear wiper does,two my blickers worked fine for first two days but then just stoped,three my seat belt does not move up or down when door is open or closed.
Has any body had any of these problem before any help would be great.All fuses have been checked
wiper, must be the wiper motor
blinker, its the flasher(pick a new one up at pepboys for $10)
i have no clue about the seatbelt
For you seatbelts, i would look for a fuse because im not sure if it has one for the belts or not, and im to lazy to check
If there are no fuses for it, by removing the panels behind the doors, you can access the motors that control the seatbelt. It could just be a loose connection to the motor, or the door sensor isnt working.
Hope it helps
Hope it helps
marauder228vw
12
Oct 20, 2012 01:26 PM
playerz808
May 30, 2003 11:40 AM
