Bolts with springs
Old Mar 27, 2005 | 05:05 PM
microsoft_sux's Avatar
Default Bolts with springs
Hey im trying to put my exhaust back onto my GSR and the bolts holding it to the header are all thats stopping me. Their 14mm bolts and they have springs on the cat side so it makes it really hard to get through far enough for the nut to thread on the other side. Does anyone know a trick to these bolts?
Old Mar 27, 2005 | 05:13 PM
projectTeG's Avatar
push real hard and screw the nut on alil then torque it down, then put the other on
Old Mar 27, 2005 | 06:01 PM
mmmm it all sounds so easy. I just can't quite push it far enough through to get the nut to thread. Even tried using C-clamps as spring compressors. No good.
Old Mar 27, 2005 | 06:08 PM
Ekay Jay's Avatar
Default Re: (microsoft_sux)
Those are always a bitch. I just use vice grips or something ta clamp it ta get the nut started.
Old Mar 27, 2005 | 06:32 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by microsoft_sux &raquo;</TD></TR><TR><TD CLASS="quote">mmmm it all sounds so easy. I just can't quite push it far enough through to get the nut to thread. Even tried using C-clamps as spring compressors. No good.</TD></TR></TABLE>
its hard but i "GET ER DONE" by hand
Old Mar 27, 2005 | 06:35 PM
dFreezy's Avatar
Default Re: (projectTeG)
everything should line up correctly if you've installed parts intended for your application. try unbolting the other end of the cat or b-pipe if it won't go. always install exhausts starting with the header end...
Old Mar 28, 2005 | 02:58 AM
the only reason I even did it this way is because the bolts on the b pipe are siezed up. It was actually a short shifter install. I'll see if I can loosen something else up on the other end and slide it closer. Unfortunately I think the pipe is a little too short. The previous owner bought an ITR exhaust which was only made for the 2dr cause they never made a 4dr and he just had an extra two inches welded on. I think it just came up a little bit short, but we'll see what happens.
WestEM1
20
Mar 11, 2005 10:41 AM
SleepnCiViC
Jan 10, 2004 06:50 PM
chankyeyes
14
Sep 9, 2003 03:39 PM
Qwikrex
Nov 25, 2002 08:30 AM
fiebru1119
May 14, 2002 10:44 PM
