Test pipe question
Old Nov 24, 2002 | 08:10 PM
Qwikrex's Avatar
Default Test pipe question
For those with test pipes, did u guys use the stock spring bolts or did u have to buy longer bolts to put it on? Is it ok to replace the spring bolts with regular ones? If not, where can I get longer spring bolts?
Old Nov 24, 2002 | 08:12 PM
Chris N's Avatar
Default Re: Test pipe question ([VTEC]TL)
I used the stock springs and washer and used different, longer bolts. Where to get different bolts, springs, etc? home depot or a place like that, i suppose.
Old Nov 24, 2002 | 08:24 PM
Qwikrex's Avatar
Default Re: Test pipe question (1107)
u can use the factory springs on new bolts?
Old Nov 24, 2002 | 08:35 PM
BlueR's Avatar
yes
Old Nov 24, 2002 | 08:53 PM
iH8RICERZ's Avatar
ditto
Old Nov 24, 2002 | 08:58 PM
blykins's Avatar
Banned
Default Re: Test pipe question (iH8RICERZ)
I used stock springs/washers w/ longer bolts, the bolts are really long, it looks kinda ridiculous-i wish i had pics, you'd laugh. They are like 8"long. They were out of the size i needed.
Old Nov 24, 2002 | 10:35 PM
Qwikrex's Avatar
Default Re: Test pipe question (blykins)
Is it neccesary to use the springs? What would happen if u didn't?
Old Nov 24, 2002 | 10:37 PM
blykins's Avatar
Banned
The springs are there so the exhaust can have some movement. The springs compress when the engine leans forward from acceleration/deceleration. If there werent springs, your exhaust would rattle really really bad.
[Modified by blykins, 2:38 AM 11/25/2002]
Old Nov 24, 2002 | 11:02 PM
Qwikrex's Avatar
Other than a rattle, any other downsides?
Old Nov 25, 2002 | 04:26 AM
typer.org's Avatar
on the cw py you get exhaust marks on the bumper. turns them black so that sucks. you can feel a difference though and also here a bit of a difference.
it does stink a bit more, but the hp gain (however minimal) is good.
Old Nov 25, 2002 | 06:45 AM
Ryuji's Avatar
New User
Big Rattles... Now I understand why my exhaust rattle like crazy...
The only thing is that it doesn't rattle on acceleration but when I decelerate...
I thought it was the exhaust protection near the fuel tank...
I'll put the springs back on and I'll see...
Old Nov 25, 2002 | 06:49 AM
Mugen Mike's Avatar
Yes, I broke my cat in half at the welds from not using the spring bolts. It has to flex somewhere, so it will flex at the weakest point.
Old Nov 25, 2002 | 06:53 AM
Ricky Rojales's Avatar
Default Re: Test pipe question (mugenmike)
Other than a rattle, any other downsides?Yes, I broke my cat in half at the welds from not using the spring bolts. It has to flex somewhere, so it will flex at the weakest point.
Yup
Old Nov 25, 2002 | 08:30 AM
typeR00-0005's Avatar
i used stock spring bolts.for the exhaust side i used the stock bolts
microsoft_sux
Mar 28, 2005 02:58 AM
SleepnCiViC
Jan 10, 2004 06:50 PM
Qwikrex
Nov 25, 2002 03:21 PM
crizmotek
Aug 7, 2002 11:22 PM
fiebru1119
May 14, 2002 10:44 PM
