Does this head look good?
Old Mar 27, 2005 | 03:00 PM
B16aDasher's Avatar
Default Does this head look good? *huge pic*
I bought this y8 head for a 100 bucks. How does it look?
fullzize pics
http://www.we-todd-did-racing....D.jpg
Modified by B16aDasher at 4:40 PM 3/27/2005
Old Mar 27, 2005 | 03:04 PM
ncskate's Avatar
Default Re: Does this head look good? *huge pic* (B16aDasher)
wheres the vtec sylinoid?
Old Mar 27, 2005 | 03:12 PM
SL0WEGG's Avatar
Default Re: Does this head look good? *huge pic* (ncskate)
damn that ******* dirty as hell. the vtec solenoid(sp?) just isnt bolted in. the head could possibly be good just looks like the oil didnt get changed very often
Old Mar 27, 2005 | 03:16 PM
B16aDasher's Avatar
Default Re: Does this head look good? *huge pic* (boostedej1)
I have the vtec solenoid, i took it off so it wouldn't get robbed. The guy i brought it from said he got a hole it his oil pan, and fup the engine. I got the block for free too. One of the pistons is melted!!
i added a bottom pic, how r the valves?
Old Mar 27, 2005 | 03:18 PM
civiccpedx's Avatar
DAUMMMMNN
Weapon_R's Avatar
looks like *** to me
Old Mar 27, 2005 | 03:19 PM
oldskooljdm's Avatar
thats really ******* dirty.....and yeh it does look like the oil wasnt changed very often
Old Mar 27, 2005 | 03:41 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: Does this head look good? *huge pic* (oldskooljdm)
that head looks fucked to me....the rist two intake valves look bent, and they are about the best loooking valves in that head
B16aDasher's Avatar
so do you think i need to rebuild it?
Old Mar 27, 2005 | 03:44 PM
e jay one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher &raquo;</TD></TR><TR><TD CLASS="quote">so do you think i need to rebuild it?</TD></TR></TABLE>
you could have bought a way better head for cheaper and easyer than rebuilding that one.
Old Mar 27, 2005 | 03:50 PM
B16aDasher's Avatar
Default Re: Does this head look good? *huge pic* (e jay one)
damn!!! thats what i thought. How much do you think it is worth? I have a z6 head, i wanted to used the y8 becuase i didnt want to have to buy a dizzy.
Old Mar 27, 2005 | 03:51 PM
Kyles ej1's Avatar
are u blind or did u have your gf buy it? if i ever saw any piece that looked like that i wouldnt spend any money on it. u could have bought a better head for like $75 u got ripped
Old Mar 27, 2005 | 03:56 PM
B16aDasher's Avatar
Default Re: Does this head look good? *huge pic* (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">are u blind or did u have your gf buy it? if i ever saw any piece that looked like that i wouldnt spend any money on it. u could have bought a better head for like $75 u got ripped</TD></TR></TABLE>
The head was bolted onto the block. I bought the head and he give me the whole longblock, so i couldnt see the bottom of the head. I thought it was just super dirty. So i got ripped? How bad?
Old Mar 27, 2005 | 03:57 PM
jlacoy82's Avatar
71.192.16.183
Nice rusted combustion chambers.
Old Mar 27, 2005 | 04:01 PM
Weapon_R's Avatar
Read again, he doesn't want to use the block.
As for the head, it's very dirty and looks like it hasn't been taken care of. Thats why I said earlier that it doesnt look very good. From what I have read, most mini-me swappers get the head for about the same price you paid, and i'd be willing to bet that its in better condition.
Old Mar 27, 2005 | 04:17 PM
B16aDasher's Avatar
Default Re: (MickeyA)
yeah, i was just going to swap head, tranny, do wiring/4-wire, run uberdata, and then turbo it.
Old Mar 27, 2005 | 04:18 PM
oxSLEEPERxo's Avatar
to clean it up, try hot tanking it
Old Mar 27, 2005 | 04:23 PM
Tiferet's Avatar
Default Re: (oxSLEEPERxo)
I would have a machine shop check it out.
Old Mar 27, 2005 | 04:37 PM
ABK's Avatar
ABK
Default Re: (drip pan)
yeah that head is not worth your time. You said that you got a z6 head, just run that. You also said that you wonna go turbo so use a z6 head because it will give you lower compression then y8 because it got bigger combustion chambers.
Old Mar 27, 2005 | 04:44 PM
TurboTagTeam's Avatar
Just run the head through a parts cleaner. You'll have to replace your valve seals though.
Old Mar 27, 2005 | 04:53 PM
d16rice's Avatar
I just recently bough a Y8 head too. I paid close to 300, but I got everything from engine block up, including aftermarket camshaft, adjustable cam gear and ECU.
I took it to a shop, and had them rebuild it.
$250 later, I had a head that looked like new.
Got it hot-tanked, milled, new valve seals, new cam seals, replaced a bent vale and some other minor stuff.
Old Mar 27, 2005 | 04:55 PM
B16aDasher's Avatar
Default Re: Does this head look good? *huge pic* (TurboTagTeam)
so a good clean and new valves are all that r needed? I thinking it might be cheaper to used the z6 head i have and buy a new dizzy.
Old Mar 27, 2005 | 04:56 PM
B16aDasher's Avatar
Default Re: Does this head look good? *huge pic* (d16rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">I just recently bough a Y8 head too. I paid close to 300, but I got everything from engine block up, including aftermarket camshaft, adjustable cam gear and ECU.
Got it hot-tanked, milled, new valve seals, new cam seals, replaced a bent vale and some other minor stuff.</TD></TR></TABLE>
wow 250 for a rebuilt head doesnt sound to bad.
Old Mar 27, 2005 | 10:06 PM
T4eg's Avatar
i would strip the head down and leave it in the hot tank over night. My old z6 looked worse than that. I had to take a puddy knife and scrape the crap off the inside of the valve cover.
Chris
Old Mar 27, 2005 | 11:15 PM
_Cyclone_'s Avatar
Poor maintenance OWNS engines.
