idle problems
Old Mar 27, 2005 | 01:02 PM
eghatchomar's Avatar
Default idle problems
i have a ls vtec setup and when i turn my car on it revs all the way to 3000 and after a min or two it starts idleing from 1000 rpm to 2000 rpm and it never stops even when im drivind it does that. i searched but i couldnt find anything i need help quick
Old Mar 27, 2005 | 02:18 PM
2lua's Avatar
Default Re: idle problems (crxomar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxomar &raquo;</TD></TR><TR><TD CLASS="quote">i have a ls vtec setup and when i turn my car on it revs all the way to 3000 and after a min or two it starts idleing from 1000 rpm to 2000 rpm and it never stops even when im drivind it does that. i searched but i couldnt find anything i need help quick</TD></TR></TABLE>
are you sure?
try type in surge or idle.
Old Mar 27, 2005 | 02:22 PM
O RLY's Avatar
Default Re: idle problems (2lua)
Okay one of two things could be happening. #1, the Idle Air Controller (IAC) is bad, which is located on the intake manifold, and it has a black selenoid on it. Check the connector. #2, you're not getting coolant to the IAC, cuz you'll notice there are two hoses that go into the IAC which consist of coolant which operates the IAC. Start from there. Let me know how things go.
Old Mar 27, 2005 | 02:24 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: idle problems (rfoster03)
Dude it could be a million things. TPS, IAC, low coolant, vaccum leak. Check it all man.
Old Mar 27, 2005 | 03:08 PM
O RLY's Avatar
Default Re: idle problems (JDM_Ej)
Yeah well a million things is right. You could say a bad head gasket is leading to overheating, and leading to coolant loss, leading to the IAC acting up, leading to idling problems. I just listed the two most common remedies.
Old Mar 27, 2005 | 04:25 PM
jurkevicz's Avatar
I have the exact same problem with my 99'si. I took the IAC sensor off and I've noticed that it was very dirty. What is the best way to clean it (if possible)?
Old Apr 1, 2005 | 10:31 PM
94hatchling's Avatar
Default Re: idle problems (jurkevicz)
use some wd-40 or some carb cleaner. sometimes if that screen is really dirty, then it can cause some idle issues.
Old Apr 2, 2005 | 10:20 AM
Well I found the problem it was inside tthe throttle body a little whole. I guess i need a new tb put i just put something in their for now to cover it and it stopped. Does anyone know the name of what im talking about?Thanks
burnoutboy
Mar 21, 2015 01:49 PM
2ndchirp
Dec 10, 2009 04:40 PM
mike93eh2
Jul 17, 2007 07:45 PM
willjs7
Aug 1, 2004 01:49 PM
crx00
Mar 13, 2004 06:39 AM
