transmission rebuild guide?
Old Jan 25, 2002 | 09:15 PM
slow_civic's Avatar
Default transmission rebuild guide?
anyone know of some books on rebuilding honda transmissions?
Old Jan 26, 2002 | 09:07 AM
-TJ's Avatar
-TJ
Default Re: transmission rebuild guide? (slow_civic)
Helm. It doesn't get any easier than the factory manual, unless you pay someone else to do it. http://www.helminc.com
Old Jan 26, 2002 | 10:40 AM
slow_civic's Avatar
Default Re: transmission rebuild guide? (-TJ)
how much different is a d series trans than a b series?
i already have a 98 integra helms and i dont really want to spend money on a civic helms just for a rebuild.
Old Jan 28, 2002 | 04:46 AM
Mista Bone's Avatar
D Tranny Guru
What SOHC tranny you gonna play with?
Old Jan 28, 2002 | 09:30 AM
slow_civic's Avatar
Default Re: transmission rebuild guide? (Mista Bone)
late model ex
Old May 9, 2008 | 09:08 PM
adrenajunky's Avatar
apparently theyre very different. i just started taking apart my y8 to install lsd. b series tranny the gears just pull out very easy but da y8 gears are all bolted down somehow. haven't goten to the bottom of it yet. m still searching
Old May 10, 2008 | 05:54 AM
hatchling37's Avatar
Default Re: transmission rebuild guide? (adrenajunky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adrenajunky &raquo;</TD></TR><TR><TD CLASS="quote">apparently theyre very different. i just started taking apart my y8 to install lsd. b series tranny the gears just pull out very easy but da y8 gears are all bolted down somehow. haven't goten to the bottom of it yet. m still searching</TD></TR></TABLE>Not true. They should come up and out of their place as a unit with minimal fuss, similar to B series.
<U>This</U> is in the FAQ, it's for a B series, but is really pretty similar to your D. Change holder is a little different.
Modified by hatchling37 at 8:36 AM 5/12/2008
Old May 11, 2008 | 07:07 PM
IN VTEC's Avatar
Default Re: transmission rebuild guide? (hatchling37)
The shift change holder is different on the D-series transmissions. You only have to remove one bolt on the D-series trannies to allow the gears to pull out of the change holder.
Old Nov 27, 2012 | 05:56 AM
nh320's Avatar
You could always check out this site.. they are a shop that does transmission rebuilds themselves, but there are a lot of good information on their blog about Honda transmissions. http://www.twincharlotte.com
YoungWisdom
Aug 25, 2014 03:25 PM
Syndacate
55
Sep 2, 2007 12:24 PM
youngracer55
Jun 26, 2007 04:19 PM
deviant1
Oct 14, 2004 05:09 AM
SPOON_BeIgHtEeNsEe
Mar 21, 2004 02:20 PM
