S7 Guages, need help w/ installation
Bought Ac Autotechnic S7 Gauges and don't know exactly where to put in power supply, "+", red cable....does n e way know or have n e suggestions on where to stick the "+" line......thanks........
Veh: 97 Accord EX V6
You could tap in to a wire by your fuse panel that comes on with your ignition but turns off after the key is out.
Grab a test light and get to crackin' .
Do you have a good power lead and a solid ground? ALso make sure the relays(if any) are all plugged in and the switch to tutn on the gauges is in the on position.
*edit* the cigarette lighter is a source that would turn on with the key but you will probably need to check and make sure it does not overload the existing wire.
LoneAutosport
Audio / Security / Video
Mar 6, 2010 09:41 AM
