why would the motor start but not go in gear?
can you out a clutch on with a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">can you out a clutch on with a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?</TD></TR></TABLE>
Huh?
Huh?
can you change out a clutch without a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">can you change out a clutch without a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?
1 question is maybe you can try.
2 question you mean by using the aligment tool came from the cm kit you got? if it fit then yes.
90hatchie
Nov 10, 2004 12:04 PM
