HELP!!! NEED TO TAKE OUT A STOCK RADIO IN A 2000 ACURA INTERGRA LS NEED STEPS
I TOOK OUT THE SCREWS OUT OF THE TOP OF THE ASHTRAP AND BEHIND AND STILL NOTHING I NEED HELP ASAP!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdMaDDiCT666 »</TD></TR><TR><TD CLASS="quote">I TOOK OUT THE SCREWS OUT OF THE TOP OF THE ASHTRAP AND BEHIND AND STILL NOTHING I NEED HELP ASAP!!!!</TD></TR></TABLE> Easiest way is to unscrew the 2 8mm bolts that hold the back of the radio and pocket, [they both come out as one pc. go to http://www.installdr.com about the same as 90/93 although it was easier on the 90/93 for yours I would use a 1/4" ratchet, 8" extention, universal , [flexy] adpt. and a 8mm socket, put a light on the drivers side to shine up there, and access the screws from the pass. side, you will need a kit and harness to install an aftermarket HU in your car, but you can backbrace the HU at the same place the OEM HU was, [one in the center] also get the Metra kit. [way better fit.
94
94
