Is this true?
Old Mar 26, 2005 | 07:14 AM
H22CL's Avatar
Default Is this true?
"When installing cams with high lifts and long durations, a few general observations are worth keeping in mind. Remember that additional cam duration can produce more usable power but too much duration may actually hurt overall performance. The problem of poor engine response begins when too much duration results in lower cylinder compression pressure (at low RPM) which in turn can reduce low RPM torque and power. Too much duration in a camshaft is not necessarily a good thing."
thats the same thing my car is doing after installing some web cams, low rpm is driving like crap. anyone else have anything to add to this?
Old Mar 26, 2005 | 09:30 AM
92TypeR's Avatar
FSAE
Default Re: Is this true? (H22CL)
Sounds like more of a tuning issue than a cam issue.
Have you had your setup tuned on a dyno before?
Old Mar 26, 2005 | 10:22 AM
aj99si's Avatar
Default Re: Is this true? (92TypeR)
Thats why there is a VTEC. You have the lower duration and lift cam for the lower rpm range and the higher lift and duration for the VTEC lobe for the higher rpm ranges. So you get good low end response and good top end power. If you had a non vtec engine and you put a radical cam yes your low end is usually going to suffer so you can make more top end power.
Old Mar 26, 2005 | 11:51 AM
projectTeG's Avatar
Default Re: Is this true? (aj99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si &raquo;</TD></TR><TR><TD CLASS="quote">Thats why there is a VTEC. You have the lower duration and lift cam for the lower rpm range and the higher lift and duration for the VTEC lobe for the higher rpm ranges. So you get good low end response and good top end power. If you had a non vtec engine and you put a radical cam yes your low end is usually going to suffer so you can make more top end power.</TD></TR></TABLE>
you sure about that??????
Old Mar 26, 2005 | 02:24 PM
danimal's Avatar
yes, i'd say that paragraph could be true for a standard, non-vtec type of camshaft function.
you'll want to know what dynamic compression ratio is, and how it's calculated, and things like cam overlap, intake valve closing event, etc... just saying "webcams" is meaningless, you need to know the cam specs... also think about why race cams are difficult, if not impossible, to run on the street.
http://www.smokemup.com/auto_m...o.php
http://victorylibrary.com/mopar/cam-tech-c.htm
Old Mar 26, 2005 | 03:11 PM
H22CL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like more of a tuning issue than a cam issue.
Have you had your setup tuned on a dyno before?</TD></TR></TABLE>
not yet, gonna look into having that done on wednesday
hpimichael02
Sep 9, 2008 08:06 AM
SupraCivic
Aug 31, 2005 05:14 PM
JDM00SI
Sep 17, 2004 04:25 AM
hybridEj6
Mar 1, 2003 06:25 AM
Malice
Jun 14, 2002 11:48 AM
