VTEC Profiles
Old Sep 16, 2004 | 11:54 AM
JDM00SI's Avatar
Default VTEC Profiles
sup,
i've been researching (noob) and foound this qoute from another user
"VTEC is a simple engine function that allows the engine to select one of two separate cam profiles: one tuned for low rpm use, the other for high rpm use. VTEC engagement depends upon the ECU you are using and/or any piggybacks also in use."
i know wat vtec is.... but why would you want to tune it for high rpm use and low rpm.....Thanks
Old Sep 16, 2004 | 12:09 PM
JimBlake's Avatar
Default Re: VTEC Profiles (bigbeasta4)
Because one single cam profile can't be real good over a really wide range of rpms.
One profile is good at lower rpms. It idles OK & works well, but starts to lose power at high rpms.
The other cam profile makes more power at high rpms, but it sucks at low rpms & maybe doesn't idle so good.
Old Sep 16, 2004 | 12:41 PM
JDM00SI's Avatar
Default Re: VTEC Profiles (JimBlake)
do you need low rpm profiles or high rpm profiles? thanks
Old Sep 16, 2004 | 12:47 PM
X2BOARD's Avatar
yes... there are 2 seperate profiles... each with different lift and duration specs.
The smaller profile performs well idling and at lower rpm. The larger profile takes advantage of the engine's rpm and is designed to produce bigger Hp numbers.
If you ran the vtec cam profile below the vtec engagement point... the car would idle horribly (if it is able to idle) and low rpm performance would suffer tremendously as the cam profile for the vtec lobe keeps the valve open too long at low rpm to be effective.
Old Sep 16, 2004 | 12:59 PM
JDM00SI's Avatar
Default Re: VTEC Profiles (X2BOARD)
when you race you want high cam profiles....so why would you adjust it to low? thanks
Old Sep 16, 2004 | 01:16 PM
X2BOARD's Avatar
larger cam profiles, as said, do not perform well at low rpm (700 to 4 or 5k) they actually will make LESS power than the smaller profile at that rpm range.
VTEC actually has 2 seperate cam lobe profiles on the cam. The engine runs the low profile up to the VTEC engagement point (4500-5500 depending on what car)... after which, the big profile comes into play. The intention is to have the crossover and power production to seem transparent.
Old Sep 16, 2004 | 08:12 PM
JDM00SI's Avatar
so u can only have either low cam profiles or large cam profiles? thanks
Old Sep 17, 2004 | 04:25 AM
crucian's Avatar
You've got to be kidding me right? I think this guy is playing around cause its been explained over and over in this post! Next topic plese!
William5353
May 8, 2016 05:47 AM
hpimichael02
Sep 9, 2008 08:06 AM
H22CL
Mar 26, 2005 03:11 PM
Brett
Jul 14, 2003 12:15 AM
B18cteg
Jun 12, 2003 07:01 PM
