Suspension & Brakes Theory, alignment, spring rates....
question about bolt that goes on top of the tophat
Old Mar 26, 2005 | 03:19 AM
eMpAtHy's Avatar
Default question about bolt that goes on top of the tophat
the tophat or whatever its called, did you guys screw the bolt all the way on top of it? or did you guys leave some room between the top of the bushings and the bolt?
if you look at lugs, they are completely tight when they are on the wheel stud, but i have space between the top of the bushing and the bolt. do i need to screw that bolt all the way down? i am trying to get rid of wierd noises after i installed my suspension.
Old Mar 26, 2005 | 05:59 AM
fireant's Avatar
Default Re: question about bolt that goes on top of the tophat (eMpAtHy)
That doesnt sound right.
Are you talking about konis inserted into the stock top hats?
There's a specific order it assembles at the top.
Old Mar 26, 2005 | 02:08 PM
eMpAtHy's Avatar
Default Re: question about bolt that goes on top of the tophat (fireant)
no, its all assembled correctly, but i am jsut wondering about the bolt on the top. its the main bolt that is on the piston. i am wondering if it has to be all the way down touching the bushings.
Old Mar 26, 2005 | 02:17 PM
fireant's Avatar
Mine went all the way down with more to go. (Koni Sports)
Old Mar 27, 2005 | 09:44 AM
eMpAtHy's Avatar
what do u mean they went all the way down? was there still space between the bolt and the top of your bushings? or was the bolt sitting on top of the bushings?
Old Mar 27, 2005 | 10:10 AM
fireant's Avatar
The nut was on the bushings.
KKRIS
27
Feb 28, 2012 09:21 AM
Homotor
Mar 21, 2008 12:47 PM
yOnKiNaToR
Jan 10, 2005 08:34 PM
basmasta7
Jan 16, 2003 06:44 AM
