car is puffing white smoke.. and leaking fluid a little?
Old Mar 25, 2005 | 05:55 PM
Dc2 Powered's Avatar
Default car is puffing white smoke.. and leaking fluid a little?
ok 3 nights ago i went to a meet and when i got to the meet i notice a little bit of coolant under where the overflow tank is and today i had to go somehwere and had no choice but to drive mycar so i did and after i got off the freeway when i got to a long red light it smoked like crazy.. i was close to home so i just came home.
i jacked up the car but cant find a leak anywhere i see some coolant drop hanging from the overflow tank.. which btw is almost empty
now that the car is cooled i checked but i cant find any hoses that were leaking i have no idea where its leaking from or why its smoking up white..
can anyone help?
Old Mar 25, 2005 | 05:59 PM
Arsenal's Avatar
Default Re: car is puffing white smoke.. and leaking fluid a little? (Dc2 Powered)
Sounds like a headgasket, is it overheating?
Check the oil cap for a white looking droplets.
Old Mar 25, 2005 | 06:01 PM
i took off the oilcap and look no white droplets
and no its not overheating the car runs fine.. and when i stop it starts smoking but when its running its fine not overheating at all
Old Mar 25, 2005 | 06:29 PM
Avenged7x's Avatar
Default Re: (Dc2 Powered)
u running a turbo? im having the same problem when slowing down after a little boost. And ya most people are just gonna tell u its the headgasket or water in your exhaust. When u put your hand at the end of the exhaust does it shoot out alot of moisture?
Old Mar 25, 2005 | 06:35 PM
no its stock *** engine except for an intake..
so i just check my dipstick and NO OIL.
do u think this has anything to do with it
iono about the exhuast...
Old Mar 25, 2005 | 06:49 PM
o and iono if this helps or not but my firend had just gave me a mugen oil cap which i just put on about a week ago
Old Mar 25, 2005 | 07:20 PM
RhdRicheeee's Avatar
your burning oil......
Old Mar 25, 2005 | 07:24 PM
integra-evan's Avatar
Default Re: (e5et)
Burning oil will give you a blue tinted smoke. Excessive white smoke will be water (coolant). If you can't find any leaks, take it to a shop, and they'll find it. Good luck.
Old Mar 25, 2005 | 07:34 PM
yea thx i'mma have my firend take a look on sunday and if worst come to worst i'll take it to my uncles shop.. i really hope its not a headgasket, i'm poor and in need of a job
Old Mar 25, 2005 | 07:54 PM
SilverDc2's Avatar
cross your fingers it isn't a headgasket....
if so, time to upgrade to spoon!!!
Old Mar 25, 2005 | 08:06 PM
IggyBcool's Avatar
it sounds to me like its on the verge of falling down the hole and going boom.
Old Mar 25, 2005 | 08:17 PM
chrisnova's Avatar
It sure sounds like the beginning of a head gasket job to me. It may not be that bad that it overheats yet. If you are definitely experiencing coolantloos s and have white smoke it woukld seem thatthe water is going through the engine.
Old Mar 25, 2005 | 08:40 PM
okkk i found the leak
ITS THE TOP OF THE RADIATOR UNDER THE BROWN PLASTIC PIECE!
how can i fix this? do i have to replace th ewhole radiator .. someone told me i could replace the top brown piece
Old Mar 25, 2005 | 08:44 PM
thaiphob's Avatar
Nikon!!!
Just replace the whole rad or you could just JB weld as a temp fix
Old Mar 25, 2005 | 08:49 PM
i have no iidea what jb weld means
Modified by Dc2 Powered at 10:44 PM 3/25/2005
Old Mar 25, 2005 | 09:44 PM
how safe is it to drive like this? what would happen if i do
Old Mar 25, 2005 | 10:55 PM
thaiphob's Avatar
Nikon!!!
Suppose you lost all of your coolant, your motor would overheat causeing long term damage. doesnt sound good does it?
Old Mar 25, 2005 | 11:33 PM
good point.. guess my springbreak is fucked. i have absoluty no money right now.. so i wont be driving for ahwile
Old Mar 26, 2005 | 07:53 AM
Arsenal's Avatar
Default Re: (Palmy Blue)
JB weld is great. Holds up very well, my brother's radiator has been held together by JB weld for the past year.
You can get it at most auto parts stores. Your spring break is not ruined yet!
Old Mar 26, 2005 | 08:24 PM
chrisnova's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">okkk i found the leak
how can i fix this? do i have to replace th ewhole radiator .. someone told me i could replace the top brown piece</TD></TR></TABLE>
OK, but this still doesn't explain the white smoke out the back. You may have overheated and then damaged the head gasket too. I sure hope the only problem is just the radiator leak. I've soldered some radiators with great success, but if you are not sure, better to go to a radiator shop for an opinion. Good luck.
thedon360
Jul 16, 2013 08:34 AM
dano88
Sep 30, 2009 09:12 AM
EtherEG93
Sep 17, 2005 08:18 PM
_Endless_
May 20, 2003 01:19 AM
LSyellowREX
Aug 1, 2002 11:37 AM
