Low compression test results
Old Mar 25, 2005 | 01:16 PM
aziantegger10's Avatar
Default low compression test results
did a compression test today on a warm motor, across all four cylinders it was 180, seems a bit low? its an 01 itr running 4 psi.. anyone care to comment on if my engines in good shape or not?
Old Mar 25, 2005 | 01:25 PM
Misfit's Avatar
Default Re: low compression test results (aziantegger10)
mine was 270 across
I would worry more about it if the numbers did not match up.. like 80 on 1 cylider and the rest were 180.
Try to do a leak down test if you are really that worried about it.
Old Mar 25, 2005 | 01:57 PM
Hybrid ctr's Avatar
even numbers
are you sure you did the compression test properly?
Old Mar 25, 2005 | 02:06 PM
i warmed up my engine, removed all pugs, and also removed the fuse , stated in the cspeed article, and had my friend hold the guage while i pressed in my gas all the way and cranked 5 times
Old Mar 25, 2005 | 02:12 PM
Jowee's Avatar
Default Re: (aziantegger10)
Some testers blow. I did 180 across in my cheap autozone one then did 230 in my Snap On. Just look for consistancy and you'll be fine.
Old Mar 25, 2005 | 02:21 PM
Default Re: (ITR 98 1162)
yeah it was a cheap one.
Old Mar 25, 2005 | 02:29 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">Just look for consistancy and you'll be fine.</TD></TR></TABLE>
Old Mar 25, 2005 | 02:47 PM
vtec.dc2's Avatar
its good that it is consistant, although its low for stock engine. does it go up if you drop oil?
76 camaro car
Apr 20, 2017 04:47 AM
guero2craze
May 8, 2007 09:15 PM
snowblind7x
Apr 13, 2005 08:12 PM
