need help with ecu codes!
Old Mar 25, 2005 | 07:30 AM
oldschoolfreak's Avatar
Default need help with ecu codes!
ok it flashes like this. long-long-short pause 7 short flashes pause 9 short flashes then it starts over. its a PW0 ecu. if you can help let me know what it means thanks
Old Mar 25, 2005 | 07:37 AM
EP3_05's Avatar
Default Re: need help with ecu codes! (oldschoolfreak)
Ok that is code 21, 7, and 9
Code 7 TPS sensor-Throttle position. Make sure it is plugged in and not broken.
Code 9 Cylinder position sensor. It is located in the distributor. Check your wiring at the distributor
Code 21 VTEC solenoid valve. Make sure it is plugged in and also check where you wired this at the ecu.
Old Mar 25, 2005 | 06:18 PM
Default Re: need help with ecu codes! (91civic)
thanks man!!
new_climber
Sep 17, 2009 08:26 AM
ilikejesus
Jul 2, 2007 06:10 PM
Doodson
Aug 1, 2006 09:59 PM
NPR Rex
May 17, 2006 09:32 AM
