JE racing pistons or SRP pistons?
Old Jan 25, 2002 | 12:46 PM
93B17A's Avatar
Default JE racing pistons or SRP pistons?
what do you guys think? cause i'm going to have a sleeved block and rods, and need some pistons
Old Jan 25, 2002 | 12:51 PM
dustin's Avatar
Default Re: JE racing pistons or SRP pistons? (93B17A)
Friends don't let friends use SRP pistons.
Old Jan 25, 2002 | 01:01 PM
93B17A's Avatar
oh yeah n if i get custom JE pistons what compression would be good for running around 15 lbs of boost
Old Jan 25, 2002 | 01:04 PM
dustin's Avatar
9.0:1
Old Jan 25, 2002 | 03:22 PM
threatcon13's Avatar
New User
Default Re: JE racing pistons or SRP pistons? (dustin)
JE 9:1.(what im running.)
Old Jan 25, 2002 | 04:47 PM
Type-ARR's Avatar
Default Re: JE racing pistons or SRP pistons? (turbo01gsr)
JE
SRP
Old Jan 25, 2002 | 06:32 PM
ekb18c's Avatar
Default Re: JE racing pistons or SRP pistons? (TurboR481)
JE and SRP are the same thing. Its just that one of them is off the shelf item.
SRP is to JE as Honda is to Acura.
Old Jan 25, 2002 | 07:01 PM
1's Avatar
Default Re: JE racing pistons or SRP pistons? (ekb18c)
Not true. You can buy JE off the shelf.
Old Jan 25, 2002 | 07:12 PM
ekb18c's Avatar
Default Re: JE racing pistons or SRP pistons? (1)
your right JE is off the shelf now. But not before..
Old Jan 25, 2002 | 09:16 PM
vhd's Avatar
vhd
je and srp pistons are the same except for some things, like the oiling holes near the piston pin bore, lighter design , and stronger struture on the under side of the dome area, they also both have the same piston pin, srp's are just a cheaper design of the je's
Old Jan 25, 2002 | 10:40 PM
TurboInteg95's Avatar
Default Re: JE racing pistons or SRP pistons? (vhd)
Hmm while all this is nice the main difference is the alloy they are made out of. SRP's are a high silicon content piston which will expand less then a JE piston when they are heated up. The allows you to run tighter piston-wall clearance for less slapping, however, they are not as strong as regular JE's
Old Jan 25, 2002 | 11:09 PM
dustin's Avatar
Default Re: JE racing pistons or SRP pistons? (TurboInteg95)
Ahh, Brian and I have refuted this crap a thousand times.
JE and SRP pistons ARE NOT THE SAME THING.
STOP SPREADING MISINFORMATION.
Thanks.
Dustin
Old Jan 26, 2002 | 08:29 AM
93B17A's Avatar
so is this "piston slap" going to be noticeable ?
Old Jan 26, 2002 | 06:47 PM
vhd's Avatar
vhd
sorry to say but the srp's uses the same alloy as the je's depending on the applications, number 1 reason why the srp's are cheaper is because it goes through less of the machining process than the je's does, things like symmetrical valve pockets, universal installations(some apps.), etc......overall they are the same, take a look at a je and a srp piston(imports or domestics) and you will see what i'm talking about, i see these pistons everyday at work so, you can agree or disagree, oh....piston slap will be noticable when the engine is cold
SpeedDreamz.com
Nov 28, 2004 07:36 PM
INVRSDITWLDBEZ
Apr 11, 2004 11:23 PM
