Internal waist gates???
Old Jan 26, 2002 | 08:05 AM
nitroedhx's Avatar
Default Internal waist gates???
Well I found a turbo off a GS-T. That little T-25 will get some use yet. I know that the stock internal waist gate runs about 12 psi. Is there any way that I can change the internal waist gate to one that acts on less psi? Say around 5-9psi? I'm running a stock block at the moment. Any one messed around with changing the internal waistgates? Or where to get one at?
Thankx
Old Jan 26, 2002 | 08:08 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Internal waist gates??? (nitroedhx)
Do you have a belt to go with that waist gate? Jk
Anyway, If Im not mistaken the stock boost on a GST was somewhere around 7psi. Dont quote me on that but it wasnt that high at 12psi. But yes, you can change it if you needed to.
art
Old Jan 26, 2002 | 09:00 AM
cyan1de's Avatar
Default Re: Internal waist gates??? (Arturbo)
on my friend's GSX, his stock boost is 14psi. and another friend of mine who is almost done swapping his SR20DET into his S14 240SX has 14psi as stock boost setting too.
Old Jan 26, 2002 | 10:01 AM
JCushing's Avatar
close the WASTE gate off with the downpipe then put a new flange on the manifold. am i right......
Old Jan 26, 2002 | 10:03 AM
nitroedhx's Avatar
So it can be changed... <U></U>
That is good to know. I did look on the Garrett site...nothing there. Any ideas for me. Like...hmm...What about rev-hard don;t they have internal waist gates or HKS?
Old Jan 26, 2002 | 10:12 AM
JCushing's Avatar
use external
Old Jan 26, 2002 | 10:55 AM
nitroedhx's Avatar
Default Re: Internal waist gates??? (JCushing)
Well the internal waist gates have a larger valves then the external ones. That and I thought that the internal one would be cheeper.
Old Jan 26, 2002 | 11:06 AM
AutoboTxEK's Avatar
I'm confused...isnt the T25 and TD04 stock PSI set at 7?...or 6.??
Old Jan 26, 2002 | 11:41 AM
nitroedhx's Avatar
Default Re: Internal waist gates??? (AutoboTxEK)
As Cyan1de said and I said earlier...the stock psi level on a GSX and GST are well above the relm of what I want to run for now. 12psi on a real boost guage...not the stock air temp guage that guesses the psi that you are running.
All I want to know is a company that makes an internal waist gate that runs at 5-9 psi. That's all I ask. I have spent this day looking from site to site and can not find any info on this. I have tried DSM sites nothing. Am I searching in a lost cause? I think not...I believe that the internal and external waist gates work by the same principles hence I think they would make one that is adjustable.
I'm thank you guys for the help thus far...but I'm still looking around for one.
Old Jan 26, 2002 | 04:16 PM
Arturbo's Avatar
Better than steak
25 Year Member
call http://www.majesticturbo.com
And BTW, its wastegate not waist. I was hoping you would catch that when I asked if you needed a belt with that...Just having fun, and harm intended.
Old Jan 26, 2002 | 07:07 PM
SIK IN DA HED's Avatar
New User
hahaha what measurement is that waistgate? does it go good with the front headlights and the rear bumper? hahah 36 24 36...
Old Jan 26, 2002 | 07:42 PM
nitroedhx's Avatar
I guess I messed up didn't I...lol
The wastgate is a 34mm which is a great size. I'll check out that site man.
si90rex
Oct 22, 2009 06:08 PM
97grnrs
Jan 6, 2008 07:07 PM
T-RO
Jun 28, 2004 04:16 PM
PsshSound
Jun 3, 2003 01:02 PM
OKSolSi
Jul 14, 2002 05:39 PM
