OVERHEATING EG BAD HEAD GASKET?
Old Mar 24, 2005 | 09:11 PM
O RLY's Avatar
Default OVERHEATING EG BAD HEAD GASKET?
Okay, this is a pretty easy one hear, but quite odd. The other day my car started overheating so I replaced the thermostat and rad cap, still overheating....then I find the top rad hose is slit, so I buy a new one of those too...still overheating...then I check my reserve for water and what do I find...SLUDGE!!! Oil, antifreeze, water, all mixed together...so I flush the system and start the car...overheats...so then I take OUT the THERMOSTAT and it still heats up to about halfway...gotta be the headgasket right?
Old Mar 24, 2005 | 09:12 PM
Kyles ej1's Avatar
Default Re: OVERHEATING EG BAD HEAD GASKET? (rfoster03)
that would be my guess
civiccpedx's Avatar
if you have oil in the antifreeze it is the head gasket. is your fan working properly?
Old Mar 24, 2005 | 09:14 PM
O RLY's Avatar
Default Re: OVERHEATING EG BAD HEAD GASKET? (civiccpedx)
The fan never kicked on, have no idea why...I have another Civic with and H22, and the slimline in it never kicks on, however the H22 EG never goes past halfway, so maybe thats why that fan doesnt kick on....but as for the D16 motor I have no idea, all fuses and relays are good.
Old Mar 24, 2005 | 09:59 PM
komat's Avatar
its the headgasket
i have the same problem like you
i have major white smoke coming out and smells sweet
Fork'd
Nov 20, 2013 10:27 AM
SIR EF9
Oct 27, 2012 10:34 AM
Bobby808
Apr 27, 2005 11:22 AM
MADEINIRAQ
Sep 9, 2002 08:09 AM
