clutch or tranny
Old Mar 24, 2005 | 08:19 PM
jpnucrx's Avatar
Default clutch or tranny
I posted yesterday about a possible tranny swap on my 88 crx. I bought a 91 crx si and the motor is great but it won't move. It starts up and everything but when you put it in gear it won't budge. It goes into gear fine, but I can let the clutch out of every gear and the thing won't even stall. Also the higher the gear I put it in the louder this clicking noise gets, almost sounds as if the clutch disc is trying to hold on. Searched and said it could be both, but I'm at a lost as of what to do.
Old Mar 24, 2005 | 08:42 PM
88cerx's Avatar
Default Re: clutch or tranny (jpnucrx)
could have a broken pressure plate and bad through barring
Old Mar 24, 2005 | 10:50 PM
.john.'s Avatar
most likely the clutch
Old Mar 24, 2005 | 11:01 PM
jpnucrx's Avatar
you think it's the clutch? I hope so i'll have to send back the clutch assembly for the 88 and get one for the 91
Old Mar 25, 2005 | 05:07 AM
92integra_gs's Avatar
im thinking its the clutch too...
Old Mar 25, 2005 | 07:12 AM
crxdonwon's Avatar
Does your speedometer move? Only reason why I ask is because I blow a differential out of one and the speedometer would be working while I was not moving.
I'm pretty sure that the clutches are different from a dx to si are you using the si clutch or the dx/hf clutch?
Old Mar 25, 2005 | 07:19 AM
EP3_05's Avatar
Default Re: clutch or tranny (civicdonwon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdonwon &raquo;</TD></TR><TR><TD CLASS="quote">Does your speedometer move? Only reason why I ask is because I blow a differential out of one and the speedometer would be working while I was not moving.
I'm pretty sure that the clutches are different from a dx to si are you using the si clutch or the dx/hf clutch?</TD></TR></TABLE>
No, that is not correct, ed clutches are only different by year. For example... the 88 clutch disc has a different number of splines than the 89-91. The 88 and 89 clutches are smaller than the 90-91 clutches.
Back to the original post....I feel that it is your clutch as well because when I blew my first J1 trans it wouldn't go into gear.
Old Mar 25, 2005 | 07:24 AM
Gearspeed-Performance's Avatar
Default Re: clutch or tranny (91civic)
Could be the incorrect clutch disc. A broken differential will also yield the same results.
Dc295kid
Dec 19, 2009 07:05 AM
B00STED Si
Jan 11, 2005 03:28 PM
turbotime
14
Oct 22, 2004 12:14 AM
green98civic
13
Jun 28, 2003 10:13 AM
FR-MOB: ThE bEe GuY
Oct 19, 2002 10:11 PM
