Car Audio equipment in House
Old Mar 24, 2005 | 06:47 PM
zumiez007's Avatar
Default Car Audio equipment in House
Alight I'm heading off to college pretty soon, and am wondering what to do with my system. My subwoofer boxes are pretty large and need the space for hauling crap back and forth (5hr drive). So I'm wondering if there is anyway to run an old car HeadUnit, and my amplifier and subwoofers, in my dorm/appartment?
Old Mar 24, 2005 | 07:26 PM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default Re: Car Audio equipment in House (zumiez007)
i would also like to know this
Old Mar 24, 2005 | 08:02 PM
shocker979's Avatar
me3, but before i had my subs running off of my home system, the reciever and radio were hooked to them but never had enough power to handle it, i wanna know if i could also throw in the amp! thatd be p i m p i n
Old Mar 24, 2005 | 08:38 PM
zumiez007's Avatar
Default Re: (shocker979)
ya, like i've seen people have a car HU mounted in their garage, and running some car speakers, but i'm just wondering how to convert 110v to 12v, other than using a battery charger.
Old Mar 25, 2005 | 03:30 AM
chucksnee's Avatar
Default Re: (zumiez007)
Go buy a converter at Wal-Mart.
Old Mar 25, 2005 | 07:16 AM
B18C_EJ8's Avatar
You'll need one of these: http://www.baproducts.com/pyramid.htm .
However, you'll need a pretty big one to power an amp... I think we run a 40 amp supply behind our board at the store...
Old Mar 25, 2005 | 12:21 PM
matt_in_sd's Avatar
You can usually run car speakers on a home system, you might need to put two subs in series. But to run a car amp in the house... Its a whole lot cheaper to buy used home gear.
Old Mar 25, 2005 | 03:34 PM
zumiez007's Avatar
Default Re: (chucksnee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chucksnee &raquo;</TD></TR><TR><TD CLASS="quote">Go buy a converter at Wal-Mart. </TD></TR></TABLE>
Honestly what the hell are you talking about?
Old Mar 25, 2005 | 03:40 PM
zumiez007's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You'll need one of these: http://www.baproducts.com/pyramid.htm .
However, you'll need a pretty big one to power an amp... I think we run a 40 amp supply behind our board at the store... </TD></TR></TABLE>
$300 ouch! is there anyway to do it otherwise?
Auex's Avatar
You need some heavy duty power supplies. For a car radio a small 15 amp power supply is fine. If you want to run an amp then it is not worth it because large power supplies are expensive.
Old Mar 25, 2005 | 06:10 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Auex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex &raquo;</TD></TR><TR><TD CLASS="quote">You need some heavy duty power supplies. For a car radio a small 15 amp power supply is fine. If you want to run an amp then it is not worth it because large power supplies are expensive.</TD></TR></TABLE>Ditto all the above 94
Old Mar 26, 2005 | 10:20 AM
DaZman69's Avatar
Default Re: (fcm)
whatever your fuse(s) are rated for in the amp and/or headunit, thats how many amps of power you need
Old Mar 27, 2005 | 11:20 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">
Honestly what the hell are you talking about?</TD></TR></TABLE>
if you dont know what a converter is, you shouldnt even be messin with anything electrical.
it converts power. they make them for automobiles, etc. its like an amplifier for a power source.
just like how you need an amplifire to boost your stock deck power so you can run subs.. thats pretty much what a "converter" does.. also known as a "power converter"
Old Mar 27, 2005 | 11:45 AM
zumiez007's Avatar
Default Re: (..::91TEG-G2::..)
I understand what a power converter is, and I have wired up dozens of car stereos. But he said, "Go buy a converter at Wal-Mart." Now, I am assuming what you and he alike, are both referring to is a DC to AC power "inverter" http://www.jcwhitney.com/autop...10101 which allows you to say, run a blender in your car.However I am wanting to put my car stereo equipment in home, and run it off of 110v power, therefor having one of these power inverters would be useless because you couldn't plug it into anything. What several people have told me, is that I need a AC to DC power "converter" which will plug into a 110v source and give out 12v power. However these pieces of equipment run over $300 for one with enough amps to run a amplifier.
Old Mar 27, 2005 | 02:06 PM
89civicdx's Avatar
https://honda-tech.com/zerothread?id=1170594
Henryug
Audio / Security / Video
Mar 4, 2011 08:20 PM
fryman
Jun 11, 2008 05:41 AM
dungsta
18
Sep 19, 2005 11:12 PM
DRxCIVIC
Jul 30, 2002 07:02 PM
sweettooth
May 7, 2002 10:02 PM
