94 civic coupe trunk leak(NOT TAIL GASKETS)
Old Mar 24, 2005 | 12:18 PM
POE's Avatar
POE
Default 94 civic coupe trunk leak(NOT TAIL GASKETS)
when it rains or when i was my car i have a leak on the back right side and leftside of the trunk but the right side leaks worse , I took pulled carpet back on of my friends ex coupe and he had a drain tube or somthing. i didnt see one of these in my dx... coupe this be the cause? also it looks like its coming from close to the back seat windows when i look at it from the inside of the trunk behind the carpet on the inside of the body. I have searched but havent found anybody with this problem.
Old Mar 24, 2005 | 12:58 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 94 civic coupe trunk leak(NOT TAIL GASKETS) (POE)
I used to have the same problem on my old ej, but that was because i reversed into a pole. Oops. During the daytime, or a well lit garage, take all the lining out of the trunk. Get in the trunk and close the lid, (obviously make sure someone can open it) and look around for light by the seals. The taillights is a common problem, especially if your running aftermarket lights.
Old Mar 24, 2005 | 02:31 PM
honda95civic's Avatar
Default Re: 94 civic coupe trunk leak(NOT TAIL GASKETS) (JDM_Ej)
water travels in mysterious ways.. the leak can be coming from anywhere.. get inside like he said.. and see where the water drips from.. hopefully u can maybe take the lights how and seal them or wherever it comes from
Old Mar 24, 2005 | 03:42 PM
Caveman74's Avatar
Default Re: 94 civic coupe trunk leak(NOT TAIL GASKETS) (honda95civic)
Mine leaked from the trunk. I pulled the rubber seal around the trunk, cleaned all the dirt, then put a bead of silicone around the border, then put the rubber seal back down on the bead. no leaks now
Old Mar 25, 2005 | 10:00 AM
POE's Avatar
POE
Default Re: 94 civic coupe trunk leak(NOT TAIL GASKETS) (Caveman74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 &raquo;</TD></TR><TR><TD CLASS="quote">Mine leaked from the trunk. I pulled the rubber seal around the trunk, cleaned all the dirt, then put a bead of silicone around the border, then put the rubber seal back down on the bead. no leaks now </TD></TR></TABLE>
i think this is what i may have to do. So i can re-use the rubber seal after i pull it off of the trunk?
and i watched were the water would drain from. it's way up in the body as far as I can see, its somwhere around the back seat window's. i just cant see back there fare enough to see where its coming from..
Old Mar 25, 2005 | 10:17 AM
IHateJDM's Avatar
My del sol used to leak in the trunk. It was coming in through the drivers side by the rear window. Water was getting in under the driver's side quarter panel, and there was a small hole on the inside of the trunk that the water just came right in though. I did a poor man's fix and duct taped it. No problems since. I know you don't have a del sol, but it's still an eg.
Old Mar 25, 2005 | 10:20 AM
POE's Avatar
POE
Default Re: 94 civic coupe trunk leak(NOT TAIL GASKETS) (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">My del sol used to leak in the trunk. It was coming in through the drivers side by the rear window. Water was getting in under the driver's side quarter panel, and there was a small hole on the inside of the trunk that the water just came right in though. I did a poor man's fix and duct taped it. No problems since. I know you don't have a del sol, but it's still an eg.</TD></TR></TABLE>
how did u get to it to see the whole and to put duct tape in it. were u looking at it from the front or the rear, u have a sol so its gonna be a bit different there in the rear. sence u dont have a back seat, and I DO
Old Mar 25, 2005 | 10:25 AM
IHateJDM's Avatar
stripped the trunk from the inside and practically broke my back all upside down looking. My carpet was wet there, so I knew the general area to start with.
Old Mar 25, 2005 | 10:29 AM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">stripped the trunk from the inside and practically broke my back all upside down looking. My carpet was wet there, so I knew the general area to start with.</TD></TR></TABLE>
oo ok i c. well thanks for your info. i will check it out today most deff.
Old Mar 28, 2005 | 12:01 PM
POE's Avatar
POE
anyone else?
Old Mar 28, 2005 | 12:08 PM
1995Ex_Sedan's Avatar
Get in there at night, and have a friend use a large spotlight on it, or in the daytime, get in there and have a friend run a hose all along the edges?
Just an idea.
Old Mar 28, 2005 | 12:24 PM
Street Ghost's Avatar
Default Re: (1995Ex_Sedan)
i currently have a leak in my coupe's trunk too. mine is coming from the trunk keyhole area.
Old Mar 28, 2005 | 12:26 PM
hatch34's Avatar
i have the same problem but i cant find the leak anywhere
Old Mar 28, 2005 | 12:27 PM
POE's Avatar
POE
Default Re: (Street Ghost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street Ghost &raquo;</TD></TR><TR><TD CLASS="quote">i currently have a leak in my coupe's trunk too. mine is coming from the trunk keyhole area.</TD></TR></TABLE>
mmm thats not my problem, sorry to hear
Old Apr 1, 2005 | 10:20 AM
POE's Avatar
POE
ttt
Old Jul 15, 2005 | 12:45 AM
s73's Avatar
s73
New User
Default Re: (POE)
i have the same issue with my 97 coupe....the tail lights are fine, sun roof drain are cleaned and re-installed.....still get a little bit of water in the trunk when i drive in the rain...i couldn't find the leak anywhere.....so this is what i did:
take off the lining in the trunk.....get some BBQ Charcoal and place in a bag and crush it up with a hammer...till its a fine dust.....then i apply the charcoal power on the areas near the leak.....and i found where its leaking.....(i think).....found a good drip mark near the rear....its one of the clips...(its the clip that is on each side of the bumper, holds the bumper up...i would of never thought it would leak from there.....)
going to seal that thing up good from the inside tomorrow.....hopefully it will help
ENTRAPM3NT
May 2, 2013 01:29 AM
Kustom X
10
Jan 1, 2013 10:56 PM
teler86
Feb 23, 2006 03:01 PM
POE
Apr 18, 2005 07:11 PM
JnyStylz
14
Apr 25, 2004 09:34 PM
