thoughts on using DA A arms
Old Mar 24, 2005 | 10:30 AM
93formula's Avatar
Default thoughts on using DA A arms
im upgrading my brakes to DA brakes. i will be using the DA knuckles. The EX knuckles arent as readily available in canada. i know i will lose some caster with the da knuckles, atleast thats what people have stated.
but what if i use DA A arms? ive found aftermarket DA adjustable A arms that claim to adjust both camber and caster. will this work for me?
Old Mar 24, 2005 | 10:43 AM
EL Vap133's Avatar
Default Re: thoughts on using DA A arms (93formula)
Are they adjustable by any chance?
Old Mar 24, 2005 | 10:47 AM
93formula's Avatar
Default Re: thoughts on using DA A arms (EL Vap133)
yes they are adjustable for camber for sure and they claim to be adjustable for caster as well.
funny thing is they have a set for the EFs which is adjustable for camber but NOT caster.
Old Mar 24, 2005 | 10:49 AM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">but what if i use DA A arms? ive found aftermarket DA adjustable A arms that claim to adjust both camber and caster. will this work for me? </TD></TR></TABLE>
Make sure they will allow you alot of negative adjustment or you can end up with positive camber.
Read this page too: http://www.ef-honda.com/ben/EFhybridsus.php
Old Mar 24, 2005 | 10:54 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">yes they are adjustable for camber for sure and they claim to be adjustable for caster as well.
funny thing is they have a set for the EFs which is adjustable for camber but NOT caster. </TD></TR></TABLE>
I think they don't make them for EFs because of the limited space.
Old Mar 24, 2005 | 12:07 PM
Eggman's Avatar
what company makes adjustable a-arms for DA/EFs? i only know of vision and a-sports... is there another one?
Old Mar 24, 2005 | 02:07 PM
93formula's Avatar
Default Re: thoughts on using DA A arms (Eggman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman &raquo;</TD></TR><TR><TD CLASS="quote">what company makes adjustable a-arms for DA/EFs? i only know of vision and a-sports... is there another one?</TD></TR></TABLE>
aim industries.
Old Mar 24, 2005 | 02:12 PM
93formula's Avatar
Default Re: thoughts on using DA A arms (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">
Read this page too: http://www.ef-honda.com/ben/EFhybridsus.php</TD></TR></TABLE>
very usefull information!!!! thanks for the link. so according to that article the DA knuckles wont affect my caster, so i can use the EF a arms and be allright.
the adjustabilty they claim is up to 4 degrees.
heres the link to the DA ones:
http://www.truckn-store.com/pr...86934
and heres the EF ones:
http://www.truckn-store.com/pr...86945
one correction im gonna have to make is that it states caster as well for the EF ones but i emailed them a while back and its camber only. may be camber only for the DA ones as well, havent emailed them on that.
Old Mar 24, 2005 | 03:09 PM
fireant's Avatar
Interesting, but what kind of ball joints do you put in em?
Old Mar 24, 2005 | 04:11 PM
93formula's Avatar
they are supposed to come with urethane ball joints
Old Mar 24, 2005 | 04:44 PM
fireant's Avatar
Keep us posted on how this turns out!
Old Mar 24, 2005 | 04:58 PM
tRex99's Avatar
hmm...but yea, the DA knuckles bolt right on and no problems with caster. and a matter of fact not even with camber when i did it, it was the same. great braking tho for a cheap upgrade
Old Mar 24, 2005 | 08:44 PM
93formula's Avatar
Default Re: thoughts on using DA A arms (tRex99)
hmmm i guess ill stick with the EF a arms then. im going with adjustable ones though because ill be lowering the car with ground controls and want proper camber. ill try them out and post back with the results
Old Mar 25, 2005 | 12:30 AM
Eggman's Avatar
post a pic of the arms when you get them. curious to see them.
Old Mar 25, 2005 | 01:02 AM
RexQ's Avatar
yeah dont do the DA A arms. i put them on my car and its a little bigger and hits the inside fender frame area. didnt wanna cut it out so everytime i go over a big bump or dip, it makes a loud banging noise from the DA arms hitting the frame. it sucks
Old May 7, 2005 | 06:12 PM
93formula's Avatar
https://honda-tech.com/zerothread?id=1238629
Modified by 93formula at 3:28 AM 5/8/2005
Old May 7, 2005 | 06:19 PM
bagpipe goatee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">they are supposed to come with urethane ball joints</TD></TR></TABLE>
urethane ball joints? scary...
i hope it meant urethane bushings.
Old May 7, 2005 | 06:27 PM
93formula's Avatar
Default Re: thoughts on using DA A arms (bagpipe goatee)
yes bushings, LOL....i tihnk.... ill let you know when i install in a few weeks
posted pics in another thread. of the c arms that is
bake1782
May 9, 2008 08:06 AM
Backk InTheDA
Jul 17, 2006 03:38 AM
Jonathan_ED3
22
May 18, 2005 12:36 PM
maxQ
10
Dec 5, 2003 07:22 AM
RineRacing
May 8, 2002 05:03 AM
