When do you need a new fuel filter
Old Mar 23, 2005 | 06:28 PM
rasinhell's Avatar
Default When do you need a new fuel filter
Is there any way to tell when you need a new fuel filter?
Oh yeah, and is there any cheap way to get a gauge to tell fuel pressure?
Old Mar 23, 2005 | 07:02 PM
Jimmy's Avatar
Global Moderator
I'm thinking they should be changed around every 75,000 miles.
Old Mar 23, 2005 | 07:12 PM
AutoXer's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking they should be changed around every 75,000 miles.
Doesn't the manual specify every 30K? I thought it did, because that's when I've always changed mine, so there must have been something on the maintenance schedule that would suggest that interval....
Old Mar 23, 2005 | 07:16 PM
pdiggitydogg's Avatar
I actually thought they had no change interval
Old Mar 23, 2005 | 07:24 PM
esohsee's Avatar
Default Re: (pdiggitydogg)
i just changed mine... it's no biggie... but i had problems because of a clogged fuel filter... stupid dirty gas
Old Mar 23, 2005 | 07:29 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I actually thought they had no change interval</TD></TR></TABLE>
You know... as I was posting that, I thought that may be the case as far as the maint. sched goes. But there are a few things that are omitted (power steering fluid, clutch fluid etc.) that need to be checked and maintained; so it may not be in the manual; but I know there is a recommended milage for it somewhere that I looked up. I'll try and find my source.
Old Mar 23, 2005 | 07:31 PM
pff whether its recommended or not......I changed mine last summer (should have mentioned)
Old Mar 23, 2005 | 09:36 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">pff whether its recommended or not......I changed mine last summer (should have mentioned)</TD></TR></TABLE>
Yeah, it should definitely replaced regularly regardless.
Old Mar 23, 2005 | 09:43 PM
MonkeyBoy668's Avatar
Default Re: (EX_AutoXer)
I replace mine every couple years. But mileage-based maintenance doesn't work so well for me, I had to replace all my belts at 50K because they were pretty damn frayed... I broke 60K about a week before the car hit 8 years...
Old Mar 23, 2005 | 09:58 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: When do you need a new fuel filter (The-Beast)
Go to autozone and get yourself a pressure gauge. Actually, sears may have them too. You can hook one up to the fitting on the fuel filter where the banjo bolt goes.
GL
Old Mar 24, 2005 | 11:11 AM
SHystrdyGSRtdy's Avatar
Default Re: When do you need a new fuel filter (HalfAnP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalfAnP &raquo;</TD></TR><TR><TD CLASS="quote">Go to autozone and get yourself a pressure gauge. Actually, sears may have them too. You can hook one up to the fitting on the fuel filter where the banjo bolt goes.
GL </TD></TR></TABLE>
i thought people normally put them near the rail or the stock fpr... not where the filter is? it doesn't matter?
Old Mar 24, 2005 | 11:18 AM
mike1114's Avatar
Default Re: When do you need a new fuel filter (SHystrdyGSRtdy)
my guage is on the fuel filter.
Old Mar 24, 2005 | 11:21 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: When do you need a new fuel filter (mike1114)
My Friend has been working at Honda for over 5 years and has never replaced a fuel filter.
Old Mar 24, 2005 | 11:28 AM
Luserkid's Avatar
Default Re: When do you need a new fuel filter (walker111)
When your car starts to stuggle, bad gasmileage, or doesnt run smoothly then its usually time to change it. Or, like in my case, you cant remember it ever being changed you might want to do that.
Old Mar 31, 2005 | 11:01 AM
xJonnyBeCore's Avatar
i changed mine recently at 125k, it was running fine beforehand, but a clean filter def helped out.
jhony_ej6
Jul 11, 2008 09:55 AM
erottik-R
Sep 15, 2006 11:03 AM
CBURKE
Jul 26, 2006 06:30 AM
Rpizzle
Apr 7, 2005 09:37 AM
chinoty
Aug 20, 2004 08:27 PM
