Offset/width specs.
Old Mar 23, 2005 | 06:01 PM
awdvr6's Avatar
Default Offset/width specs.
Let me see if I got this straight. I want to run a set of 16x7 Rota Slips. If I run a 40mm offset as opposed to a 45mm I will have less chance of rubbing and with the 7in width I could run a 225. So all in all a 225/40/16 on a 16x7 +40mm would be the best choice? TIA
Old Mar 23, 2005 | 06:02 PM
Mike_C's Avatar
basically you're asking if the +40 would be better than the +45? yes.
and if you can run a 225 on a 7" wheel? yes.
Old Mar 24, 2005 | 11:34 AM
Green JDM-R's Avatar
Default Re: Offset/width specs. (awdvr6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdvr6 &raquo;</TD></TR><TR><TD CLASS="quote">Let me see if I got this straight. I want to run a set of 16x7 Rota Slips. If I run a 40mm offset as opposed to a 45mm I will have less chance of rubbing and with the 7in width I could run a 225. So all in all a 225/40/16 on a 16x7 +40mm would be the best choice? TIA</TD></TR></TABLE>
Depends on where you are concerned about the tire rubbing. Basically, the +40 would stick out the wheel well farther than the +45.
Old Mar 24, 2005 | 02:24 PM
awdvr6's Avatar
I was worrying about it rubbing the fender with such a wide tire. I just want to make sure nothing rubs and that im making the best selection that I can. From what im reading I would want to adjust mysetup to a +45mm to keep the tire better inside the wheel well.
Old Mar 24, 2005 | 03:11 PM
Mike_C's Avatar
that may rub on the inside though you'd really have to find someone that has tried it.
soooo bump!
Old Mar 24, 2005 | 05:11 PM
awdvr6's Avatar
Bump. I know some one has had to have done this already
Old Mar 26, 2005 | 12:26 AM
awdvr6's Avatar
ttt
Old Mar 27, 2005 | 10:20 AM
awdvr6's Avatar
ttt
Old Mar 27, 2005 | 10:12 PM
Alstare's Avatar
Default Re: (awdvr6)
Bump for an answer....
I was wondering the same thing for my new wheels this year...
Old Mar 28, 2005 | 12:56 PM
awdvr6's Avatar
ttt
Old Mar 29, 2005 | 10:19 PM
Import13alla's Avatar
IMO just get +40 offset with 205/45/16...it's the sure deal and will save you some bills in the process.
Old Mar 30, 2005 | 04:39 PM
awdvr6's Avatar
ehh how much difference will it be...100 bucks maybe? Im going to buy rims once and I want them to be the best ones for what
I want. Thanks for the reply!
Old Apr 4, 2005 | 03:08 PM
awdvr6's Avatar
ttt
Old Apr 7, 2005 | 07:26 PM
96GSRcx's Avatar
I'll find out in about 2 weeks how wide a wheel and tire can be run on a 96 hatch- Ordered wheels 15 x 7.5" with 225-50-15 tires. I plan on rolling the fenders and quarters to make them clear. wish me luck.
Old Apr 8, 2005 | 12:34 PM
awdvr6's Avatar
nice! what wheels? What offset?
Old Apr 8, 2005 | 08:57 PM
96GSRcx's Avatar
they're custom made Bogart Racing 3 piece RR10 wheels sized 15 x 7.5 with a 45mm offset.
Old Apr 10, 2005 | 04:26 PM
awdvr6's Avatar
nice! Keep us in the loop!
Old Apr 14, 2005 | 10:40 AM
CivicMike's Avatar
im about to pick up some 16x7 slips...I am having the same dilemma, want as wide a tire as possible (i was thinking 215/50/16) but would go wider if possible....i guess ill need to roll the fenders but that shouldn't be an issue....
Old Apr 14, 2005 | 01:22 PM
awdvr6's Avatar
I had 215/40/17s. After I rolled the fenders everything was fine. Not sure what the offset was on those rims.....
Old Apr 19, 2005 | 11:08 AM
CivicMike's Avatar
im keepin this post alive, anyone out there running 40 or 45 offset wheels with 225x50+x16 tires? (please post pics and fender rolling expereince)
Old Apr 20, 2005 | 07:40 PM
awdvr6's Avatar
ttt
Old Apr 22, 2005 | 11:52 PM
Hulkmanj99's Avatar
hmmm.... 225 on a 40 is gonna be cutttin it really really close. i would do a 215 45 16 if i were you. there would be no problems with rubbing, i am gettin some 38 offset SSR's and running 215's, and thats gonna be close also!
GL
Old Apr 23, 2005 | 03:48 PM
awdvr6's Avatar
ttt
Old Apr 26, 2005 | 02:37 PM
makeshift's Avatar
Default optimal offset
along the same lines... what is the optimal offset for 16" rims on 205/45s for a teg? I've heard that 35 - 45 are fine, but is there an offset that is preferable?
I just ordered slips with a 45 offset and I'm wondering if I should have gotten 40 instead. My car is dropped less than 2" so I'm not too concerned about rubbing.
Old Apr 29, 2005 | 03:17 PM
awdvr6's Avatar
ttt
