help 97 accord engine rumbleing..and shakey at idle<<<<<
when my car is at 1k (idle) the engine is real shakey and i cleared up all the cels... cant figure it out.. checked all vacuums ... its only shakey at idle ....checked timming anoyone had this problems before
It sounds like mounts to me as well. If it is an automatic what you can do to check them is have a person get in the car with it running and put it in gear and hold the brakes and then rev the car a bit to see if the motor is rocking more than it should.
naw its not the mounts ithas energy inserts all around it started throwing code 43 which says check fuel pressure reg ... i changed out reg. and injectors ...still runs the same ....... it manuel..
when i drive it slightly struggles when picking up when im driving on the highway it will struggle then all of a sudden it just drives normal and throws the code... it almost like the car wants to die at idle
arielb1
Apr 14, 2016 07:12 PM
jits1980
Mar 9, 2016 07:38 AM
zumiez007
Jul 10, 2009 12:13 AM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
