any of you gsr owners running b16 pistons?
besides higher compression, do you get better top end, midrange or anything?
or is it just higher compression? i'm debating if i should put some in my gsr motor or not.
check out this sweeet compression calculator if you want exact numbers:
http://www.bojangs.com/calculator/
If i remember right, the b16 pistons will give you a little better top end power.
SolidSpruce
Aug 27, 2003 05:35 AM
